Alright I have been battling this damn idle issue for severa months now. It all started after my turbo install.
Basicly the cars idle when the clutch is pressed in even while driving slow can fall to almost 0 RPM. If I am going 60 and I press and hold the clutch the RPMs will fall to 0 then return up to 800. If I accelerate then immedatly press in the clutch, the car will stall then a second later restart itself. Also the idle is the worst when the head lights are on. When switched on they can drop the idle to about 200 RPM.
So far I have confirmed there are no intake leaks by spraying choke cleaner on all joints, welds and connections after the maf and all over the intercooler to ensure no leaks. I have released the idle screw so far that it is all but come out.
THe VAC on the car is 20-21 PSI is great according to both Flyin miata and BEGI and rules out the possibility of a vacuum leak.
The idle fuel pressure is 35 PSI which is within range.
HELP!!!!!!!!!!!!!!
HELP!!!!!!!!!!!!!!
