mp3 front grill
promp3
how do you remove that friggen thing! :mad: I want to take it off to get the top part painted to match like the ms protege
#here i am again...#
ok, remove the radiator support brackets, you'll need needle-nose pliers to get teh two brakets hidden inside the radiator crossmember...then remove the "pop-tabs" in the center of the grill, then remove carefully, there are two tabs at the top of the bumper...watch for those...good luck.
what a pain in the a$$! I dont think there were enough clips on that part. Mazda should recall that one for a grill with 30 more. Its a very high stress area after all. (rant)
It took me like 2 hours! and I consider my self mechanicly experinced I was afrade to horse it out but I had to use all my strenth to pop that sucker out only to relise later that the top part I want to get painted can come out!
ME
(stupid)
oh well it needs a good cleaning anyways thanks alot for your help
you shouldnt have a problem, when i put my billet grill in I just knew that i had to get a little rougher than I thought. but the billet grill will need to be modded, the top section that is. you will see when you recieve it.
Hey guys what is the website for billet grills. Also is this the grill that installed over the old one?
