MP3 Aftermarket Guide Changes
Deals from RR-Racing.com
Hey all, here are the products I offer for the Protege 5, MP3.
**Big Brake Conversion**
www.RR-Racing.com
Converts to 2-piece 12.0" diameter, 1" thick, directional curved vane rotors w/ stock calipers. Utilizes billet aluminum rotor hat, billet caliper relocation brackets, and available cross drilled or slotted (no additional cost). This kit is super high quality stuff, way better then anything AEM makes, for details check out www.RR-Racing.com
$580.
**Fidanza Billet Flywheels**
www.RR-Racing.com
In stock and at the lowest price. Simply the best quality aluminum flywheel you can get.
$260 + $15 shipping (BLOWOUT SPECIAL)
**Clutchmasters Stage I Fidanza flywheel Combo**
www.RR-Racing.com
Again, the lowest price on earth.
$500.
**Clutchmasters Stage III Fidanza flywheel Combo**
www.RR-Racing.com
$680.
thanks,
-Rafi
www.RR-Racing.com
Mazda / Probe GT Performance Parts
Please add the following to the aftermarket guide.
Thermal Exhaust
2.25" full stainless steel exhaust for the P5. Top quality and sound. From the cat back.
$585
http://www.fmprotege.com
Please replace the BEGI listing with the following:
FM/BEGI turbo kit
A complete system, as desgned by Bell Engineering. Cast-iron manifold, Garret T3 turbocharger, front mount high-efficiency radiator, fuel management, boost gauge - everything you need. At 6 psi, this has shown an increase of 71 hp and 76 ft/lbs at the wheels. Price will be between $3000 and $3500. October release
To add to the list of websites:
FM Proteg
Performance parts such as turbo kits, exhausts and more.
Thanks!
PSst! The BEGI listing needs to be changed.
FM/BEGI turbo kit
A complete system, as desgned by Bell Engineering. Cast-iron manifold, Garret T3 turbocharger, front mount high-efficiency radiator, fuel management, boost gauge - everything you need. At 6 psi, this has shown an increase of 71 hp and 76 ft/lbs at the wheels. Price is $3595 with a one-year warranty. Now available. http://www.fmprotege.com
Also, the Ground Control suspension:
Ground Control Coilover kit
Quality Eibach springs on adjustable perches. Allows corner-weighting and ride height adjustment. Springs are available in a huge range of rates. Fits right on the MP3 and other Proteges.
Price: $399.00
Ground Control camber/caster adjustment plates
Allows you to maintain good alignment with a lowered car.
$299.00
Thanks!
New RR-Racing Big brake kits...
Could someone post the info about my new big brake kit:
Details on the 4 piston 13" Big Brake Kit:
Price = $1220 (see www.RR-Racing.com for PICS)
=> 13.0"x1.0" thick 2 piece race rotors, directional vanes, aluminum hats, cross drilled or slotted
=> KVR Python 4 piston calipers, red laquer coated, ultra light 3.5lb weight
=> 4 wheel Goodridge Stainless steel brake lines
=> Anodized CNC machined caliper brackets
=> 3 bottles Lockheed racing DOT 5.1 brake fluid
=> KVR brake pads
thanks,
Rafi
Updated guide to htmp and added a few new things.
Still have alot to add. JIC stuff, lots of interior stuff, much more.
Will add asap.
Don't know if you've already heard this, but Tripoint Motorsport's turbo kit is being redesigned right now.. so you might want to take that off until it's back up.. but thanks for the list, it's helpful.
OK if I say somethin already covered let me know.
First I am assuming here the 2.0L in the p5 is same as the mp3 which is why they list most parts for most applications?
Anyway;
headers;
Anthony Woodford Racing Header 4-2-1 2 piece maintains 02 sensor no CEL
www.anthonywoodfordracing.com
AroSpeed header
also 4-2-1 2 piece 199.95 +shipping
The intake camshaft (Jspec is also available from www.protege5online.com for 155.00
I know I have seen the black Injen RD CAI for 202 shipped, ill find the link from a friend later.
For catbacks I know Greddy, Racingbeat, mazdaspeed, Bosal, Thermal all make em for the 2.0L, also some new ones recently developed like from www.teammoonexhaust.com about the same price as others but supposedly has the nicest sound and look?
In short shifters Pacsetter makes one for the 2.0 also that has an adjustable ball on it that you can change your throw from a 15% reduction up to 80% and change the height of the stick also.
In sprngs I know TEIN makes some also for the pro.
hm, I kow I left a few things out but that protege5online site has alot of stuff for the 2.0
hm, i think thats it for now
-Alex
hi-boost has released their turbo kit for the 2.0 its designed for the P5, but we all know its the same under the hood. produced 210 whp.
www.hiboost.com
there is no price on their site though....
