FYI because I didn't find this info when I searched.
These
https://www.ebay.com (commissions earned)
(I purchased the Valentine One Rj11 one)
Will fit the molex connector on a 2017 CX-5 with Homelink. The trick is to get the pin under crimp where it rolls into the insulation.
So looking at the side of cable entry, you will see the crimp rolls into tabs from both sides into the insulation for a strain relief. The channel it leaves along the bottom wall of the molex connector, is where you want to target the pin entry.
I thought the pins were too think initially and thought I'd have to get the MTX ones from bendmount, but finally figure out the sweet spot for the cheap ones.
Hope this helps anyone else looking for a tap.
These
Code:
