mazdspeed engine swap
orange pro
mazda protege mazdaspeed
Hey i have Msp threw a rod couple months back bought a fsde motor low miles till i build up the one i blew . Have a few ?s i know the mbsp on the fsde doesnt have a oil return need to be tapped on the pan or the mbsp on the fsde ? Then can u remove the oil feed adapter and coolant adapter from the fsdet is it bolt ons? Plan to do it this weekend thanxx
You have to swap the oil cooler and the coolant lines, most people tap into the lower oil pan for oil return.
So tapping into the pan is ok i heard u should tap into the plate were the original one is? And the oil cooler and coolant line can be removed from the fsdet right its just a hose for the coolant line and a plate for the oil cooler
