Mazdaspeed3 water intercooler
only problem with air to water intercoolers is if they become heat soaked it takes a far greater time to cool itself off.
why him breaking his motor has nothing to do with the water to air setup being bad.
the water wont heat soak if you have a properly sized front mount heat exchanger and a decent resovoir. most kits come with fans so it cannot be an issue if you size everything properly.
