you will be fine. i have the 20mm RB (MSP/MP3) rear sway bar, along w/ the stock ES front bar. stock rims and tires for daily driving.
the rear bar makes a huge difference, and is perfect IMO. if i had continued autoXing it (instead of the 'rolla), i would have switched to the AWR 21.5 bar or (*maybe*) the Delsing 1" bar, b/c i like the car really loose. but i autoX a lot...for occasional autoX use, the RB is perfect.
my 5-speed ES is loaded as well (spoiler, sunroof
, side airbags
)...however, it's still only 2625, much lighter than a 'speed. really, the weight dist isn't much different model-to-model.
i mounted mine directly to the car (ES horseshoe brackets, MSP bushings and endlinks), but it's worked fine except for the clunk, but i think the "right" way is to get the AWR brackets and bushings. stick w/ the MSP endlinks...a new set is in my near future. and grease the bushings up good.
nothing. and no one has suggested ther eis a problem with the mazdaspeed STRUTS (the green adjustable ones, you mean?) on a protege sedan. or a P5, for that matter.
J dragon said:So what's wrong with mazdaspeed Struts on regular sedan protege's?
