mazdaspeed 3
Mazdaspeed Protege
im looking to buy 2008.5 ms3 interior but cant find anywhere the answer to my question what will i need to modify to make the front and back seat fit into a mazdaspeed protege
fronts just need proper rails/sliders or you need to make your OE brackets work. If you use OE your seat height will be raised about 2". Rears you'll need to custom mount the rear seats since they mount in different places and youll have to section out a bit of the bottom seats so they fit properly.
i figure for the protege the bottom bench should be okay since its bigger then a p5 and is a one in the msp like the ms3 i should ask my room mate to let me test fit his ms3 seats
I don't know if the MS3 rear seats can be fit in a sedan, I believe I have seen them in the P5s only.
the layout is pretty much same as a p5 cuz the p5 seats can be mounted in a protege the only difference is the bottom bench in the p5 which is a 2 piece to make room for the cup holders on the rear doors
do u know which rails cuz i cant be any taller in the car
many of us have used the wedge rails/sliders without issues.
speedracer has the speed rears in his sedan
cup holders in rear doors of the P5? the seats fold so that you can use the full length of the hatch and have the back of the seats even with the floor.
cup holders in rear doors of the P5? the seats fold so that you can use the full length of the hatch and have the back of the seats even with the floor.[/QUOTE]
i do agree with the function of the seat and i maybe wrong on the cup holders
No cup holders but the seat backs are different, P5s have pull handles and don't bolt in the same way. They are not the same, top or bottom.
