Antoine
Administrator
Congratulations to color0!
Vote Now for October
Brian Ma
2013 Mazda3 i Touring
Power/MPG:
Cut-airbox SRI
JBR Skyactiv Panel Filter
Custom Magnaflow 11132 exhaust w/ 3.5" exit
Ford E-Focus Rear Motor Mount
Chassis/Suspension:
BC Racing ER Coilovers w/ custom digressive valving
Swift Springs 9kg/mm F
Hyperco Springs 650lbs R
SPC Rear Camber Arms
Corksport 28mm RSB
Hotchkis Billet Sway Bar Brackets
Corksport Rear Toe Links
Tri-Point Rear Endlinks
Powergrid Front Endlinks
GTSPEC Front Strut Tower Bar
Corksport Mid-Chassis Brace
Brakes:
Mazdaspeed3 front brake conversion
Mazda5 rear brake conversion
Stoptech Street Performance pad set for Mazdaspeed3 F/R
Stoptech stainless lines F/R
Edelbrock speed bleeders
Wheels/Tires:
Enkei NT03+M 18x10.5 +30 F/R
Bridgestone RE-11 285/30/18 F/R
Eibach 10mm spacer F
Adaptec 12mm spacer R
ARP extended wheel studs
Muteki SR48 Burning Blue Neon lugs
Exterior/Aerodynamics:
Garage Vary Replica Front Lip
BMSPEC birch plywood front splitter
240ZG Fender Flares
Bayson R side skirts
SPMS P1 Spec Rear Wing
BMSPEC custom wing risers
BMSPEC custom rear diffuser + subframe
VG Sharkfin Antenna
Interior:
Flush-mounted BC rear damper remote adjuster
Custom eccentric aluminum shift knob
Lighting/Electrics/Misc:
Hella Optilux Extreme Yellow 65W 9005 high beams
Hella Optilux Extreme Yellow 55W H11 low beams
Corksport LED Hatchback Brake Light
Brake light flasher circuit
Hella Supertones
Rear wiper delete
Brian Ma
Power/MPG:
Cut-airbox SRI
Chassis/Suspension:
Corksport 28mm RSB
Brakes:
Wheels/Tires:
240ZG Fender Flares
VG Sharkfin Antenna
Interior:
Hella Supertones
Rear wiper delete
