Mazda5 Suspension fitment / specifications database
ErikO
2012 Mazda5 GT
Hey Everyone,
I've been researching suspension options for the Mazda5 since ordering my new 2012 last week. I think it might be worthwhile setting up a sticky for suspension options and compatibility with other Mazda / Ford / Volvo models. I'm happy to edit and moderate this thread if the mods would like, though I'm usually online on this forum once or twice a day. If I have overstepped my boundaries as a noob, please let me know and I'll remove this thread.
suggestions are welcome, but perhaps we can start with this:
2005 - 2010 Mazda 5
Swaybars (brand, front diameter, rear diameter)
- OEM Mazda5: 24mm solid, 20mm solid
- OEM Mazda3: 21mm solid, 20mm solid
- OEM Mazdaspeed3: 26mm solid, 26mm solid
- Hotchkis: 29mm hollow, 32mm hollow
- Autoexe: 24mm solid, 22mm solid
- COBB: 29mm hollow, 32mm hollow
- Racing Beat: 28.5 solid, 27mm solid
- OEM Mazda3 rear bar rate roughly 230 lb/in
- OEM Mazdaspeed3 rear bar rate roughly 470 lb/in
- Tri-point Engineering rear bar rates: setting 1 - 750 lb/in, setting 2 - 825 lb/in, setting 3 - 1000 lb/in
OEM Strut/shock Compatibility
- Mazda3
- Mazdaspeed 3 (slightly firmer than Mazda3)
Aftermarket Strut/shock Options
- Koni FSD kit (P# 2100-4045)
- Koni Sports (yellows) (P# 8741-1490L & R front, 8040-1354 rear)
- Autoexe suspension kit (assumed to be coil-over), height adjustable
- Bilstein Sport: (front right - 35-110774, front left - 35-110767, rear - 24-110815) (Mazda3 fitment)
- Bilstein HD: (front right - 35-110743, front left - 35-110736, rear - 24-110808) (Mazda3 fitment)
Lowering Spring Options (Brand, amount of lowering, spring rate)
- H&R: (P# 29152), 1.4" front 1.3" rear, unknown
- Autoexe: 30mm front 30mm rear, unknown
2012+ Mazda5
- Racing Beat: (rear only) 27mm solid
- Autoexe: 20mm front 20mm rear, unknown
There have been past theads very similar to this with many details. Perhaps you can search for them to build this. Also, content like this really should be in a table format (easier to compare and cross reference) but forums don't support that.
also, anything that fits a mazda3 / mazdaspeed3 will also fit a mazda5 - the spring rates and damping "May" not be optimal, but they will fit.
