Hi
Please Help as I am at a loss. I have had an issue the last 2 weeks now where all of a sudden when I hit 3000 RPM I lose power. If I cluth and drop to 1000 RPM the power kicks back in again as far as 3000RPM. This will get worse the longer I drive it and start to cut out at 2000 RPM. I have to keep a stedy rev between 1000-2000 RPM most times so I drive in a high gear. I have had a few local garages hook up to computers and one picked up the below fault code.
P2401 Evap Emmission system leak detection ring control unit.
The guy in the garage said to me that normally that refers to the EGR being faulty so I had my own mechanic clean it out and it was sooted bad. Still no good. He then shut off the EGR and tested and still same. I have been doing a bit of reading on it and seen a few saying about the MAF so I disconneted that and tested and still same problem.
Any help anyone can give is much appreciated. I have it booked in with Mazda for diags next Wenesday at a cost of 55 first hour. I dont have much choice in this and was wondering if anyone can point me to issue or for me to try anything before I send it up.
Its a Mazda 5 2.0 Diesel sport 2006.
Thanks
Thanks
