badmanners
Hey guys, So me(Charles) and Mazda323_T(Chris) are working on the 323 GT 88 1.6T FWD. I've gone ahead and made a checklist of the things we need to do. Please don't shy away from contributing to the list of things we need to check or how to go about it.
Tomorrow I'm removing the entire engine harness and repairing EVERYTHING as well as having the stock IC TIG welded at a friends garage so we can see if the car has any other problems. When I drove it to my dads garage Thursday the idle and rpms were very unstable. At idle it would chock without a decent amount of gas (2000rpm) and during driving, getting above 3000rpm was difficult and while I was trying to accelerate a Green light showing the turbine kept flashing, so I'm guessing either overboost from the turbo so it was detecting a pressure drop.
A few other things. I have no speedo reading or Temperature reading on the cluster. The temp reading might be due to a cut wire which I will check out tomorrow but I'm worried about the plastic wheel on the transmission that transmites the signal through the cable to the cluster. Where can I find this part, how much is it and how hard to change(write-ups please)
So here's the checklist:
16 New Lug Nuts - Bought today
Attach + Adjust Hood Latch
Attach Air Flow Meter and create bracket
Attach Bumper and Bumper Support
Attach Fenders + Align
Attach Grill and headlights
Blow Off Valve (next summer)
Boost Controller (how much psi is safe on stock IC?)
Boost Gauge ($50 from autoparts store)
Change Coolant
Change Fuel Filter
Change PCV Valve - Bought today, any write-ups of where it is?
Check All Lights
Check all suspension
Check Floor
Check Power Steering Fluid
Check Turbo Oil Fitting - Owner said it was leaking
Clean and Adjust Handbrake
Delete EGR - Which hoses do I block?
Fix Glovebox - Missing Lock Latch, anybody have a source for this?
Fix Inner Plastic Fender
Fix Intercooler - Doing tomorrow with TIG welder
Fix Shifter Bushings - Only have 3rd, 5th and Reverse....sometimes
Fix Shock Tower
Fix Trunk Lock - It needs a new trunk lock + key, anybody got one?
Front/Rear Disks + Pads
Front right tie-rod
Get new P-Flow +adapter - Ordered, installing next week
Open All Door Panels and grease window motors
Open Headliner and check sunroof motor - I hear it turning but no movement, help?
Repair Engine Wiring Harness - Doing tomorrow
Shifter Knob - Anybody have one for cheap, otherwise ebay I think.
Used Battery
Wiper/Washer System - Everything was disconnected and there is no reservoir, anybody have a source for this piece?
The things that have been done to the car by previous owner are pretty much just the spark plugs, wires, cap and maybe the rotor, he doesnt remember the rotor and he changed ALL the vacuum hoses.
Any input would be great, thanks guys
Change Coolant
Change Fuel Filter
Check All Lights
Check Floor
Fix Shock Tower
Front right tie-rod
Used Battery
