Aricjm15 said:thos3 ba5tArdZ
TWM Performance said:We'll be releasing out Mazda 3 shifter later this month. I'll update the release here as soon as the part is available.
Thanks,
Karel
TWM
The kit will include aluminum bushings which mount the shift assembly to the chassis. These replace the stock rubber bushings and provide a much more direct, solid shift feel.goldwing2000 said:Bushings, too?
TWM Performance said:The kit will include aluminum bushings which mount the shift assembly to the chassis. These replace the stock rubber bushings and provide a much more direct, solid shift feel.
Aluminum is actually much tougher than polyurethane in terms of standing up to wear. Normally polyurethane is used in applications where some flex is still required or there is some vibration to absorb, i.e. engine mounts, rod actuated shifters (like the Protege 5).goldwing2000 said:Why aluminum instead of polyurethane? Won't it wear?
Just curious.
TWM Performance said:Aluminum is actually much tougher than polyurethane in terms of standing up to wear. Normally polyurethane is used in applications where some flex is still required or there is some vibration to absorb, i.e. engine mounts, rod actuated shifters (like the Protege 5).
Because the Mazda 3 shift linkange is cable actuated there is very little vibration transmitted to the assembly. Aluminum bushings create a far more rigid link between the assembly and the chassis and offer a much more solid shift feel. Basically they remove all of the vagueness or slop from the shifter.
Thanks.
