MAZDA3 and MAZDA6 tranny swap
FLAMEBOY
Mazda3 Red SP23
are both model tranny swapable?
and if we change from 5 to 6speed, do we need to reprogram the ECU, or is has nothing to do with it...
thx in advance guys,
Silas
wait
what?
the M6 has a 6-spd auto???
that would be kewl to pull one off a wreck and build it up, in advance to swap it and add a turbo...
ooooh yah
the auto trannys are computer controlled, meaning putting in the 6 speed auto won't work without a standalone or reprogramming the ECU (good luck!)
you can swap the 5 speed MANUAL trannys of course, the one on the mz6 has a better final drive (for road racing/acceleration)... it has the same ratios as the JDM axela (japanese 3) tranny... the stock tranny (the one on the 3) for the US version is geared towards economy because many north americans b**** about "high rpms" on the highway
hmmm.... i have mazda3 and i have problem with my 5spd manual gearbox.... so if i use 5 spd manual from mazda6 to my mazda3, thats mean i have to buy clutch and flywheel for the mazda6.... not for the mazda3? is this correct?
damn.... i just purchased mazdaspeed clutch and exedy flywheel for mazda3... fark...
is it straight swap, or is it require some modification.... also how bout the ECU? do i need to reprogram?
If someone could find out if that was possible, that would be cool. After i get back from iraq, i wanna do a engine swap to the 2.3 with the 6speed tranny, so been wondering what it would take to do that.
the engine is the same, the gearbox is the same.... so there's NO reason at all that the clutch and flywheel wouldn't interchange!
I don't know about the gear ratios in australian versions, so you'll want to make sure that the mazda6 one is better than the 3's... what I have posted applies to the US/Canadian versions only
so you are saying we could interchange both tranny??
That would be great since our tranny is very weak. But I dont
understand what you are saying...why spec (or any other clutch company) would make two different clutches for the 3 and the 6 if only one would be necessary for both tranny??
