Mazda2 (2007) 1.5l - Repair Work Question
Hello, new to this forum!
I just took my Mazda 2 (07 plate) for an MOT which it passed, however has several of advisories as follows:
Repair as soon as possible (minor defects):
  • Nearside Front Suspension arm ball joint dust cover severely deteriorated (5.3.4 (b) (i))
  • Nearside Front Lower Anti-roll bar linkage ball joint dust cover severely deteriorated (5.3.4 (b) (i))
Monitor and repair if necessary (advisories):
  • Front Registration plate deteriorated but not likely to be misread (0.1 (b))
  • Rear Registration plate deteriorated but not likely to be misread (0.1 (b))
  • Nearside Rear Seat belt webbing slightly damaged or frayed (7.1.2 (b) (ii))
  • Offside Play in steering rack inner joint(s) ()
  • Offside Rear tyre worn to 3mm
  • Nearside Front Brake pipe corroded, covered in grease or other material (1.1.11 (c))
  • Offside Front Brake pipe corroded, covered in grease or other material (1.1.11 (c))
  • Central Brake pipe corroded, covered in grease or other material (1.1.11 (c))
  • Nearside Rear Brake pipe corroded, covered in grease or other material before and after brake hose (1.1.11 (c))
  • Offside Rear Brake pipe corroded, covered in grease or other material before and after brake hose (1.1.11 (c))
  • fuel filler neck/breather pipes corroded
  • fuel pipes corroded at rear
  • exhaust system corroded
  • sump pan corroded
  • Nearside Front Brake hose has slight corrosion to ferrule (1.1.12 (f) (i))
  • Offside Front Brake hose has slight corrosion to ferrule (1.1.12 (f) (i))
  • Nearside Rear Brake hose has slight corrosion to ferrule (1.1.12 (f) (i))
  • Offside Rear Brake hose has slight corrosion to ferrule (1.1.12 (f) (i))
  • Offside Front Shock absorbers light misting of oil or has limited damping effect (5.3.2 (b))
Whilst I know some are minor works such as the numberplate, I was wondering does anyone know roughly how serious these issues are, and roughly how much it may cost to repair? The car has done 95,000 miles if that helps. I don't know much about cars or anything so any advice on how much it would cost would be ideal so I can begin saving!
Thank you.
New Threads
