mazda protege5 only firing 2 cylinders help!!
Sheadensp5
2002 Mazda potege5
Hey guys , so my car would sputter and idle rough for a while now but now it's running on only the cylinders with the ignition coils above them. I have changed spark plugs egr valve cleaned new coils, cleaned maf . I don't know what to xcheck next maybe the timing is off? Let me know what you think thanks!
if it is only firing on the cylinders with the coil packs, then that means the #1 cylinder isn't firing. Perhaps a cam position or crank position sensor? (but yeah, I'd also start with the wires)
