Mazda protege differential
Mazdaspeed Protege 2003.5
I'm looking for a base model open differential and differential only (full assembly) for a g-15mr, I REALLY need one A.S.A.P. Ring gear is has 78 teeth, I don't know if they are different or not in diff models just a preference. Please help!
Msp uses an LSD, I'm assume ing you broke yours. You can get a differential from any 01-03 protege or 626. But open diffs suck, spend the money now and get an mfactory and be done with it if you have the money.
Not only 626s and Proteges, but also Probes and MX6s. I replaced my transmission with an open diff equipped Probe transmission, and I like the gearing, but having an open diff is horrible. I didn't realize how much it would suck until I did it... Then after I got my Pope 3" downpipe, Tubular manifold, and 3" single-resonated, catless exhaust the turbo spools so ******* fast that all I do is spin the tire when I hammer it... So, just keep this in mind. I also agree with tweety about the MFactory.
Ya I have an open diff in my 323, when it spins in 2nd it wil switch between tires and throw me everywhere in the car. It's rediculous
scanning through threads, and reading this...it made me laugh! haha
yeah...I'm not entirely familiar with open diff design...I mean i get what an LSD does, and how the different types work...but open diffs, these mazda boxes seem SO much worse than some other cars that also have open diffs.
A few years ago i pretty much decided i'm no longer driving my p5 in the winters. Even with good winter tires, it was laughably bad if there was more than a few inches of snow on the ground. I switched out my 16" studded good-year something or others to my gf's 1999 Jetta (different bolt pattern, we just bought new steel wheels), which also has an open diff...Can't say i love her car, but it goes ANYWHERE with those things...same exact tires...we go snowboarding and have been in 15+"s of snow on the back roads in the mountains, and hers wouldn't stop...2.0L, 5 speed manual, does have abs, but no traction control or anything like that...it'll get one wheel going from a stop, but at least that will still pull the car forward and eventually stop after the car is rolling...Mine would spin one wheel, and seemingly go sideways and backwards...anything but forward...
I don't know if its the weight of ours, or the gearing, or what...but one wheel will bust loose on pretty much anything but bone dry pavement...i'm long overdue for an LSD.
What model Jetta does she have that doesn't have traction control???? I managed an independed European shop for 6 years and I can't remember a single one that didn't have traction control when dealing with the ABS system... Get me the part number off of the ABS control module if you're ever poking around in there. I find it odd a car in the Northeast would not be fitted with ASR or ESP... But there is always that chance I suppose.
And I've had no issue going snowboarding in W. Virginia in my P5. The "blizzard" in the Northeast that dumped something like 22" of snow in just a few hours in W. Virginia and had shut down I77 for 16 hours just north of Winterplace, I was able to travel fine in my P5 even after getting off the interstate. I was able to get up the mountain roads that were snow covered. I did get 1/2 way up the last hill only to come around a corner to see an F250 that was stopped which caused me to reverse back down 75 feet or so in order to regain enough speed, but I was still on an incline. That's not the only case at which it's done well in the snow, but definitely the most extreme condition. This was on Kumho ASX's also.
Its a 1999.5 Jetta GL, i think...or maybe the 'GLS', the previous owner took the rear badges off. Its the 2.0L, 5 speed manual...but does have some higher end options; heated leather seats, factory CD player, power everything...tilt/telescoping steering wheel, etc...it doesn't help that she bought it (before we got together) with no manual, no history, and with a title that at first had mismatched vins. Her insurance company worked everything out, so its properly matched back up with her registration and title...but raises questions about the previous owner for sure.
Definitely has ABS...but as far as 'traction control', it might be an issue of definitions...I am positive this car has NO adjustment to power output...If you bust a tire loose it will spin until you let off the gas with no input from a computer. So that is what i meant by 'traction control'. It may have some sort of stability management related to the ABS system, that i'm not sure of....but again there is no system controlling the engine output; what little there is anyway...and if it is supposed to have a system controlling that, it hasn't worked since she bought it in 2008. Wouldn't surprise me, this car has a plastic dipstick tube to the oil pan...that cracks from engine heat in about 25,000 miles and needs replaced each time. There is a hot coolant 'splitter' made entirely of plastic, that has split 4 times since she owned it...letting all the coolant spill out. The cup holders snapped from a single can of soda...the roof lining is sagging, and holds water if its parked in the rain. The vanity mirrors on both side snapped off, and we had to remove the bulbs just to keep them from being permanently on...etc, etc, etc.
it truly is a pos...Now don't get me wrong...the P5 would get around in regular snow conditions...most of my problems with heavier snow were simply from 'plowing', as the front is pretty low and would easily start to hold a lot of extra snow pretty quickly. The awr mounts didn't help either, tire spin is nearly on or off because of zero flex in the drive train. hers isn't modded at all, with a high round front end...and hers has always been far better in heavier snow because of that...but i'm positive if i'm not careful with the throttle in that it will one wheel as long as i want it to, its just easier to control with next to zero engine power, a 300lb heavier car, and a clutch that slips like its made from a rubber band.
Must be nice my mp3 has trouble going down hill in the snow.
Why would you even drive in that in a fwd car?
ha yeah i remember the winter i bought my car in Feb 2002, got 5 or so inches of snow one night when i was staying at my parents place up in the mountains ..nice long downhill driveway (when leaving the house)...I couldn't back the p5...down hill...if there was ever a 'should've bought the WRX i looked at' moment...that was it. That was the stock dunlop w/e's, but still...it was sad. Even after a good set of winter meats, i was never blown away by it. I'd get around, but still worse than some other FWD's with all seasons.
I was going snowboarding, like I do 10+ times a year, and I'm confident in my ability to drive a car is said condition, obviously my confidence in my driving ability and the car proved to be true. I've taken the P5 through tons of snow and have never had an issue with the exception of one time- It snowed 6-8" while I was snowboarding and couldn't get out of the parking spot which was already "rutted" about 3" or so when I parked, making it so I had to immediately "climb" up 9" of snow. Once I was out of the parking spot I didn't have an issue.
its cool preferio, I'm being a little misleading on how bad the P5 is...I'm not questioning my own driving ability either...I can do most of it in the P5, its not that. I have a 1997 Wrangler Sport with winter tires, and pretty much only use that for winters as its gas mileage is a joke (i now only insure it from December to March)...that is what i consider an acceptable winter thing to get around in...no matter what road conditions there are, that thing has absolutely no trouble whatsoever. It walks right through 3 foot drifts of powder like they aren't even there. hell if the roads are completely closed...just drive it through the woods haha. I too snowboard often, live just 20 miles from the highest ski-able peak in PA (still not very high, though)...through the winter, they'll regularly leave some access roads completely snow covered up there, with only the main line in being plowed...which is a good 15 miles out of the way from my house. No FWD will pass those roads with a couple feet of snow on them...
I was only saying the P5 is worse than some other FWD's i happened to have access to. The Jetta does it better...its higher off the ground, and considerably heavier. I never once got the p5 completely stuck once it had winter tires on it...but spinning up hill while seemingly just letting the engine idle got old pretty quickly for me.
I'm sure you guys have much more signifcant amounts of snow and more often than I do.
I'm not saying your a bad driver but anything more than 3" and my protege isn't moving or stopping lol. I wish I would have taken some videos of how good my Honda did. I was having no issues in 5" of snow/ice while trucks in front of me were sliding everywhere. Guess every car is different though
Install shield if you want something good on gas and good where ever you want it to go look into an awd vibe/matrix. My moms will go anywhere at anytime with summer tires. When we get a lot of snow I usually take it and go around and pull people out of ditches for a few bucks
