from the comparisons of the two intakes side by side they look pretty much the same,the intake hose and air box look the same.I havn't compared part numbers yet.As far as us useing the dual stage manifold it won't work,we have a differnt wiring harness & ecu.I looked the other day for extra connectors to hook up a factory cruise control and abs but the connectors are not there,Mazda use to use a common wiring harness in each model(2.0l lx-2.0l es have the same engine harness & body harness except the es has abs,cruise,sunroof)
