Mazda of the Month | VOTE NOW for March!
VOTE NOW for March!
  • Total voters
    83
  • Poll closed .
Status
Not open for further replies.
Antoine
Administrator
Please note the following rules & guidelines.
Your cooperation and participation would be greatly appreciated, thank you.​
ENTRY RULES:
* You must own the Mazda you are entering into the contest
* Any form of photo/image manipulation is not allowed except for adjusting and enhancing image color, contrast, tone and levels etc
* If you wish to enter two or more times in a row, you will need all new photos of your Mazda for each consecutive month entered
* Once you have entered (posted) your Mazda, you may not withdraw from the contest
* The MOTM contest & rules are subject to change in order to maintain a fair & fun environment for the Mazdas247 Community
ENTRY REQUIREMENTS:
Format
1. Username
2. Name
3. Year and Model
4. Minimum 2 pics / Maximum 5 pics of your Mazda *NO ATTACHMENTS PLEASE!
5. List of CURRENT modifications *NO "WAITING TO BE INSTALLED" MODS PLEASE!
EXAMPLE:
Antoine
Antoine *
1995 Eunos Cosmo
- Redline Diff Oil
- Hi-Per Coolant
- Autoexe Intake
- Autoexe Springs
- Volk Racing Rims
- Redline Tranny Fluid
- Blitz Boost Controller
- MAZDASPEED Exhaust
- Speedmaster Engine Oil
- Optional Factory Aerokit
- Paint Protection Coating
- Autoexe Spark Plug Wires
- Carbing Front Strut Brace
- Alpine Navigation Headunit
- Yokohama DNA S.drive Tires
- Defi Boost Gauge & OLED Display
- Upgraded Original Headlights (HID)
- Carbing Cooling Plate (not pictured)
- Custom Center Console and Glovebox
PRIZES:
* Your Mazda showcased on the Mazdas247 Home Page!
* A Mazdas247 T-Shirt and a pair of Mazdas247 Decals!
> Sponsor a Future MOTM...PM Antoine for details!
VOTING RULES:
* Votes only count for the MOTM from those Members that have joined Mazdas247 during the previous month or before
* There is NO tolerance for PERSONAL CAMPAIGNING threads, posts, private messages (PMs), images or links (including signature and or image links). The creation of such ANYWHERE on or off the Internet including Mazdas247 will result in immediate disqualification...If you are disqualified, your entry & poll listing WILL remain but your votes will be removed
* Creating GENERAL "Vote for the MOTM" threads and links is allowed and encouraged
GOOD LUCK AND HAVE FUN!
This month's theme is...
BOOSTED MAZDAS
* Boosted as in Turbo or Supercharged ;)
DEADLINE to VOTE is April 2nd '14!
NOTE: Please keep this thread ON TOPIC.
Thank you and once again, good luck!
Bikingpro5
JT
03 Protege5 Supercharged
Exterior
DG CF Grill- OE mesh insert
DG CF mirror covers
DG CF rear spoiler
DG CF rear valance
Xcelerated CF hood
JDP CF lip
MSP Lip
Isport CF spoiler add on
TRFS Morimoto mini retrofitted headlights
Aerocatch locking latches
Hella supertones
rear wiper delete
8mm spacers- arp extended studs
Deleted door panels
complete respray in a darker Laser blue
roof sprayed Ford GT Black
Shaved hatch
Shaved front Protege5 bumper
tint 5% everything behind the "B" pillars
Rolled fenders
S2000 antenna
City Light mod
Yellow high beams/drl
AAC sag fix
JDM side marker lights- came off a car in TNT from Japan
JDM taillights- came from friends in TNT
Interior
Speed3 front seats- rewrapped in leather/suede and blue stitching
Black suede headliner
Black suede pillar covers
Blue suede wrapped center gauge pod
rewrapped black suede door panels
wrapped dual suede cargo cover
black flocked rear plastics
MSP floor mats
rewrapped rear seats- leather/suede with blue stitching
CDM raised arm rest- top wrapped in leather with blue stitching
AEM gauges- boost, volt, wideband, temp
MSP door sills
OE Mazda auto dimming rear view mirror with compass/temperature
Intermittent wiper switch
Pioneer double din
Infinity components- 6.5" all doors
Polished gauge rings
wood hatch floor
Suspension/wheels/brakes
Ksport coilovers
GT SPEC Vbrace panel
GT SPEC Vbrace arms
GT SPEC Front strut bar
GT SPEC Rear strut bar
GT SPEC Lower tie bar
GT SPEC Ladder brace
GT SPEC Rear cage
GT SPEC Trailing arms
All GT SPEC pieces powdercoated satin bronze
Jay Racing Aluminum lateral arms with custom SS bushings and SS hardware- powdercoated gloss black
Raceline adjustable endlinks- rear
Jay Racing Adjustable endlinks front
Mazda6 front brakes
AWR rear sway bar
Energy suspension sway bar bushings- greasable rear bushings, front bushings
Mazdaspeed6 18's powdercoated black 215/35/18 tires
White line control arm bushings
CS braided SS brake lines
Engine bay
CR3 Rad brackets
CR3 ADP
CR3 Washer kit
CR3 Coolant can- AN fittings to rad
CR3 Pcv can- AN fittings direct to valve cover and to manifold
relocated lightweight battery- its where the OE jack was in hatch
626 intake manifold- shaved and unneeded vac spots filled
OBX header- ceramic coated and wrapped
Clutched M62 supercharger
CX racing FMIC
welded aluminum IC piping- wrinkle black
Perrin fuel rail
440 injectors
Jay Racing thermal spacers- TB and IM
Corksport exhaust hangers
mini vac line tuck and wire tuck
1.8L valve cover- shaved, cam cover cutout and AN fittings welded
1.8L coils and wires
Mishimoto rad
Mishimoto slim fans 10" & 12"
SU motor mounts
NRG CF hood dampers
AEM FIC
Corey CF AC delete panel
Vibrant vacuum block
AC/CC delete
Lewis7789
Evan Lewis
2006 Mazdaspeed6
Mod List:
Engine/trans
- New OEM long block (installed 11/2013)
- Autotech HPFP
- CPe TMIC
- ATP 3" catless downpipe (DEI wrapped)
- Magnaflow cat back exhaust
- Fidanza lightweight flywheel
- Luk OEM clutch
- MD SS plate
- JBR oil baffle and BSD kit
- JBR shifter weight
- JBR boost tubes and bypass tube
- JBR TB and IM thermal spacers
- HTP 3" intake w/ K&N filter
- one step colder plugs
- Forge V2 bpv
- EGR delete
- MD Oil catch can
- Cobb AP V2
- Dashhawk
- AWR motor mounts (all three)
- Turbine Tech rear diff bushings
- Turbine Tech front diff bracket
- Braille 2015 battery and bracket
- CorkSport polyurethane exhaust hangers
- BC Racing coilovers
- SPC front ball joints
- Enkei RPF1 (gold) 17x8 +43 w/ 235/45-17 Continental Sport Contact 2 (DD)
- 5Zigen FN01R-C (orange) 17x9 +35 w/ 235/45-17 Hoosier R100 slicks (track/auto-x tires)
- PlastiDipped OEM wheels w/ 235/45-18 Blizzacks (winter wheels)
- Hawk HP+ pads all around (summer)
- Hawk HPS pads all around (winter)
- Techna-Fit SS brakelines
- Wilwood 600 brake fluid
- Painted black calipers
- Whiteline rear sway bar
- Moog endlinks all around
Interior
- Corbeau FX1 seats, sliders and brackets
- TWM small Type-R shift knob
- TWM shifter extension
- Corksport LED interior bulbs
- 1/4" stereo plug for le iPod
Exterior
- Matte white PlastiDip
- Tint 35% front 15% rear
- eBay stubby antenna
- eBay taillights
- SLOW MS6 license plates. lulz
princess peach
Pablo Chois
2004 MazdaSpeed Miata
Suspension\Chassis
BossFrog Frog Arms
Koni yellow shocks
GC sleeves and springs (375 F \ 250 R)
custom alignment
Wheels & tires\brakes
215/45/17 Direzza ZII
HP+ pads
SS lines
Engine
Mazda Comp motor mount
ebay IC
BEGi CAI
BEGI throttle body intake
FORGE BPV
FM downpipe
RC 550 injectors
Hydra Nemesis 2.7
AEM TRU BOOST
AEM Wideband UEGO
Miata Roadster short shifter
Interior
TWM shift knob
Hard Dog M1 roll bar (harness bar cut out)
Hard Dog harness bar
Track Dog Racing seat bracket
RCI racing harness
UltraShield TDR Rally Spor Seat
hardwired Escort 8500X
Alpine headunit
Boston Akoustic speakers
Kicker sub 8"
custom footwell sub box
2 amps
blue LED on cluster
white LED map light
Exterior
35W HIDs
custom dents and scratches
custom faded paint
white LED license plate lights
removed fog lights
Mazda fog light covers
removed power antenna
stubby short antenna
chiefmg
Mike Green
2000 Miata SE
Engine:
BRP MP62 supercharger w/intercooler, 10 psi of boost
EV14 550cc injectors
M-Tuned dual feed fuel rail w/stainless braided fuel lines
'01 factory header w/949 Racing header blanket
Koyo 37mm radiator w/Lexan fan mount and two Spal fans
EUDM square top intake manifold
Coolant reroute
COP conversion
Enhanced MegaSquirt 2 ECU
Innovate MTX-L wideband
ProSport electronic boost gauge
Powdercoated valve cover
Flyin' Miata 13.5 pound flywheel
949 Racing clutch
RoadsterSport midpipe
Brainstorm dual outlet muffler
Suzuki Cappucino washer bottle w/GarageStar wrinkle black cowl cover
IL Motorsports engine mounts
Chassis:
Flyin' Miata VMaxx coilovers
Mazdaspeed rear diff mounts
Tuckin' 99 front fender braces
949 Racing front/rear braces
Jackson Racing front/rear sway bars
Cobalt three point front shock brace
Flyin' Miata frame rails w/butterfly brace
Hard Dog Ace rollbar
Konig Lightspeed 15 X 7.5 w/Toyo T1-R 205-50/15
Konig Flatout 15 X 8 w/BFG Rival 205-50/15
DBA drilled/slotted rotors front/rear w/PowerSlot pads and braided stainless lines
RyokuRob tow hooks front/rear
Interior:
Recaro LX-C seats
KG Works woodgrain instrument surround
AWD brushed needle caps
revlimiter satin black vent rings
Tribute in-dash radio w/6 CD changer
Clearwater speakers
IL Motorsports pedal covers
Exterior:
Factory ground effects
Home Depot front lip
MSM rear spoiler
Zoom Engineering fuel lid
Stock headlights modified w/The Retrofit Source HID conversion
Front/rear Mazda emblems painted body color
Project-G vent window vents
Body color taillight overlays
Coppertone
Lauri Haase-Sumlin
2003 Mazdaspeed Protege
ENGINE/POWER TRAIN:
Wiseco Pistons
K1-Rods
GT2871 Turbo
Steedspeed Manifold
440 Injectors
Doc B Oil Pump upgrade w/ relocation kit
AWR Oil Pan
Custom FMIC
Haltech Platinum Sport 1000
Custom SRI
Turbosmart Dual Port BOV
CR3 Radiator Brackets
CR3 Washer Kit
Mishimoto Radiator
Slimline Radiator Fans w/ shroud
3" Custom Turbo Back Exhaust w/ 3" Race Muffler
Full Set SU Motor Mounts
TRANSMISSION:
Exedy Stage II Clutch
Fidanza Lightweight Flywheel
EMCO Gears
SUSPENSION:
BC Coilivers
Powerslot Slotted Rotors
Cobalt Friction Pads XR-3 and XR-5
Techna Fit SS Brake Lines
AWR RSB
AWR Rear Adjustable End Links
Custom Front Adjustable End Links
Russell Speed Bleeders
INTERIOR:
AEM UEGO Wideband
Tru-Boost Electronic Boost Controller & Gauge
AEM Digital Oil Pressure Gauge
Empire Tuning Short Shifter
TWM Piston Style Shift Knob
Auto Power Half Roll Cage
EXTERIOR:
DG Carbon Fiber Hood
TIRES & WHEELS:
Kosei K-1 TS w/ Kumho V710 225/45/17
Enkei (Black) RPF-1 w/ BF Goodrich R-1 235/40/17
Motegi F-7 w/ Yokohama Parada Spec II 215/45/17
mspeedP5
Mark Speed
2002 Mazda Proteg 5
ENGINE:
Mental Addiction Motorsports Ver.1 Street Sleeper turbo manifold w/ARP studs, Garret GT28RS Turbo, Tial 38mm External Wastegate w/dump, Greddy Type S BOV, MAM FMIC and Charge Pipes, Massive K&N Cone Filter, Custom 3" downpipe w/cutout, Corksport Power Series DP back exhaust/hangers, Perrin Fuel Rail w/liquid-filled FP gauge, Deatchwerks 600cc Injectors, Walbro Fuel Pump, NGK BKR8E plugs, Ported head w/ARP studs, Integral/Mega Cycle Stage 3 Intake & Exhaust Cams, "Focus"/Tri-Point adjustable cam gears, Supertech O/S Valves-Dual Springs-Titanium Retainers-Bronze Guides, A/C/Cruise Control/VTCS/VICS/EGR/Throttle-body coolant delete, Signature Sound Valve Cover/PCV System/Oil catch can, Wossner 8:1 Pistons, Pauter Rods, AWR Oil Pan, Custom Built oil pump w/Peterson Regulator, SPAL pusher 2nd fan, AEM Water/Methanol injection w/med.nozzle, Mishimoto aluminum rad, Samco coolant hoses, Custom Coolant reservoir tank, 626 Ported/Polished IM, Custom CNC'd MPSport.net Battery Tie-Down/Oil Cap
ELECTRONICS/MONITORING:
Haltech Platinum Sport 1000 EMS, Greddy Profec Type S EBC, Autometer Ultra-Lite Oil Press./Wideband AFR/30psi Boost
DRIVETRAIN:
B&M Short Shifter w/TWM M1 Abrams satin 460 gm. weighted shift knob, SPEC Stage III Clutch, AWR 90 durometer engine mounts(all 4), M-Factory LSD, PAR/Tri-Point 1st-5th Custom Ratio Straight Cut gearset.
WHEELS/TIRES/SUSPENSION/BRAKES:
SSR Type-C RS 17x8 Rims/Dunlop Direzza Z1 215/40-17(street), FD RX-7 Rims/Kumho V710 245/45-16 (track), BC Racing BR-Type Coilovers, AWR 21.5mm Rear Sway Bar, H&R Trak+ 5mm, GT Spec trunk cage, Ractive Chrome Front Strut Bar, Powerslot Rotors F/R, Hawk HP+ (F), HPS (R), Goodridge Braided Brake Lines, ABS delete, Blackworks hydraulic e-brake
INTERIOR:
SPARCO Pro 2000 seat, SPARCO R383 Steering Wheel, NRG Quick Release Hub/Adaptor, Autopower Roll Cage w/dual Door Bars, G-Force Pro 6 Pt. Harness, WINK 5 panel mirror, BSCI FIA Type A roll bar padding
EXTERIOR/APPEARANCE:
Gemini Composites RC CF Hood, Replica Auto-Exe Front Grille, EL Door Sills, 5% Tint B-pillar back, Vent Visors, Moonroof Wind Deflector, Hella Fogs/Lows, Phillips BlueVision Highs, Optional DRL's, Custom Painted Brake Calipers/Fuse Box/Interior Trim, 15% Windshield Banner Tint, MP3 Front Lip Splitter, rear wiper delete, front wiper delete
Dyno Tuned by 5252 Motorsports
Herblenny
Phil Sohn
1993 RX-7
Engine:
- Adaptronic ECU for FD PNP (http://www.turblown.net/store/index.php?productID=280)
- Garfinkle Delrin Custom mounts
- Pettit Polished AST
- Koyo N-Flow Radiator
- Custom Carbon Fiber Cooling panel
- Fast acting AirTemp sensor
- BNR Stage 3 Twin Turbos
- Ported 13B-REW engine
- Custom Grounding kit
- Polished Efini Y-pipe
- Polished upper intake manifold
- Polished 90mm Rotary Works Throttle body
- Polished Greddy elbow w/injector ports
- Apexi GT Spec FMIC
- Custom polished pipings By: BNRSupercars.com
- Constant tension T-blot clamps for IC pipings and Intakes.
- HKS seq. BOV
- HKS twinpower ignition amp
- RE-Amemiya SS Dual Dolphin Tip Catback
- SS Pettit DP
- Mazdaspeed ignition wires
- FEED oil filler cap
- FEED coolant filler cap
- Added R1 Dual oil coolers
- Braille light battery
- Braille Verticle mounting kit
- Unorthodox Alternator pulley (red)
- Unorthodox Power steering pulley(blue)
- Exedy Hyper Single Clutch Kit
- Simplified seq twin set up
- Polished hardline intake pipes for secondary intake.
- Ported JDM Upper Intake manifold and polished by David Garfinkle.
- Also all the misc. vacuum ports have been welded shut and cleaned up and polished for cleaner look.
- Pettit Racing water pump pulley
- 2 x 4 blade fan set up for better cooling
- HKS RS intake with KN filters
- Tweakit Racing tensioner pulley kit
Suspension:
- M2 launch kit
- FEED coilovers
- Fender Braces
- Racing Beat sway bar brace
- Racing Beat sway bars (front and rear)
- AutoEXE front brace
- Racing Brake Rear Brake kit with HP+ pad
- Hawk HP+ pads rear
- Newly sandblasted A-arms and other suspension parts
- SakeBomb AP Racing Big Brake Kit with Ferrado pads
- Braided SS brake lines
- Racing Beat sway bushings
- New Delrin bushings for all suspension parts
- Transmission brace
- Raceshop Rollbar
- Dragon’s diff brace
- Rays Engineering Volk Racing TE37SL 189.5 Front and 1810.5 Rear.
- Toyo R888s 255/35 front and 295/30 rear
Interior & Stereo:
- Works Bell Short hub
- Works Bell Quick disconnect
- Works Bell hub lock
- Personal Steering wheel
- Converted Black interior – including, door panels, rear panels, head liner, seat belts, and black main carpet
- RZ floormats
- Rare moon roof interior cover
- JDM rear seats with panels, seat belts, and special rear carpet
- Bride Artis III Navi
- FEED Shift knob
- Red leather stitching shift and ebrake boots
- LED interior lights
- RE-Amemiya steering column pod with 52mm Prosport boost gauge
- JKL Engineering Carbon Fiber Gauge cluster, hood AC panel, shifter,etc (Flattened look)
- JVC 7inch AV system
- RE-Amemiya speedo cluster gauge
- FEED Carbon fiber rear trunk add on.
- Base model hatch cover
- OEM fog light switch to turn FEED HID driving lights
- Carbon look oem door step
Exterior:
- Plasti Dip Storm Cloud Grey exterior (www.DipYourCar.com)
- Carbon Vented hood
- APR GT300 with custom aluminum stands by Adam Griffith
- One off Feed Carbon Gas door (Shine Auto)
- Feed Type 2R front bumper
- Feed Carbon fiber canards
- Feed Carbon Fiber side skirts
- Feed wide front fenders
- FEED rear wide flares
- Rotary Extreme hood dampers
- R-magic oil cooler ducts
- FEED front tow hook
- Adam Griffith rear tow hook
- RE-Amemiya Pro Carbon rear diffuser
- Custom LED tail lights
- Custom rear bumper CF signal covers
- Rare glass moon roof
- LED signal lights in FEED signals
- HID FEED Signal lights
- Spirit R fender badges
- Efini front are rear badges
- Carbon look rear bumper lights
- Carbon fiber FEED gas door (one off made)
- APR Carbon Fiber side Mirrors
- Custom front canard add on
- Carbon Cooling panel (custom, made by me)
- LED Front bumper strips
- R-Magic HID head lights
- FEED door handles
- Carbon Fiber back of the door handle covers.
- Back Off 3rd light flasher
- ShineAuto rear tail light lip
- Feed carbon Fiber bumper guard by Shine Auto
bigsho
Sohan Ghosh
2007 Mazdaspeed3 GT
Suspension/Braking-
-H&R Coilovers
-SPC camber arms
-Hotchkis 32mm Front and Rear Sway bars, rear is on stiffest setting
-OEM end-links
-Stoptech slotted front rotors
-Stoptech drilled/slotted rear rotors
-Hawks HPS front and rear brake pads
-OEM GenPu wheels, powdercoated Hollyburn Orange
Engine/exhaust goodies-
-Autotech HPFP Internals
-HTP 3.5" Intake
-Street Unit Top Mount Intercooler
-UR 3" catted downpipe
-eBay Test Pipe
-Forge V1 BPV (blue spring, 2 shims)
-Mazdaspeed Accessory 3" Catback exhaust
-Cobb AccessPort (tuned by El_Diablo)
-Cp-e 75 duro Rear Motor Mount
-James Barone Racing 80 duro Passenger and Transmission Motor Mounts
-PnP intake manifold with VTCS delete
-JBR EGR Blockoff
-Throttle Body Coolant Bypass
Appearance/Misc stuff-
-3M Clear Bra for front bumper, front portion of hood and mirrors
-Tinted Tail lights
-Yellow halogen High Beams
-Cp-e Triple Gauge Pod with Pro Sport Performance series amber/white Boost, Oil Pressure, and Oil Temp Gauges
-OEM Mazda Spin On Oil filter conversion and ProSport sandwich plate
-JBR heavy shift Knob
-Sure Shortcut and counterweight
-2RBO WGN license plates
Evan9999
Evan Rosewicz
2009 Mazdaspeed 3 GT
Engine/Transmission
CXRacing FMIC
Corksport SRI w/ TIP
Corksport Racepipe
Hypertech
Autotech HPFP
Red Line MT-90
Synapse BPV
JBR Rear Motor Mount 80 duro
JBR Passenger Motor Mount 80 duro
JBR Transmission Mount 80 duro
JBR Short Shift Plate w/ shifter bushings
Suspension/Wheels/Brakes
BC Racing Coilovers
JBR Rear Sway Bar
JBR Rear Camber Arms
MSR Style 045 18x8 +35 Wheels w/ Continental ExtremeContact DW 225/40/18 (DD setup)
XXR 552 17x8 +35 wheels w/ Hoosier slicks 235/40/17 (Track/Auto-x setup)
OEM Gen1 MS3 wheels w/ Blizzak LM-60 225/40/18 (Winter setup)
DBA 4000 T3 Rotors
Carbotech AX6 Pads
Corksport SS Brake Lines
Wilwood EXP 600 Brake Fluid
Interior/Exterior
TWM Big Type-R Shift Knob
White LED Interior Lights
White LED License Plate Lights
CPe TowPlate
Side Molding Delete
Smoked 3rd Brakelight Overlay
Forgot to enter...
Douh!
BRC does it every time.
Good luck everyone! Nice to have so many race cars this month (and so many from Ohio) :)
Forgot to enter...
Douh!
and having two that you could have entered makes it worse.
Lots of good choices, I'll have to think about my vote for a bit.
Definite one of the closest contests in recent months! Good luck to everyone........no losers in this group of cars! Great cars and even better people!
I just realized that I have listed in my Interior section an Autometer rollcage! lol *Damn autospell*
Hey Antoine, If you want/can change it to Autopower... :D
My vote went to chief. A lot of great cars entered this month but that SE color combo is just so damn beautiful.
Status
