Mazda of the Month | ENTER NOW for November!
Status
Not open for further replies.
Antoine
Administrator
Welcome to the Official Mazdas247.com "Mazda of the Month" Contest!
* The MOTM is OPEN to ALL Mazdas! *
Please note the following rules & guidelines.
Your cooperation and participation would be greatly appreciated, thank you.
ENTRY RULES
* You must own the Mazda you are entering into the contest
* Any form of photo/image manipulation is not allowed except for adjusting and enhancing image color, contrast, tone and levels etc
* If you wish to enter two or more times in a row, you will need all new photos of your Mazda for each consecutive month entered
* If you become a MOTM winner, you may not enter the same Mazda again until at least 12 Months after the month you had won. However, if you own several Mazdas, you are welcome to enter those as well * Each Member may NOT enter more than one Mazda per MOTM contest * Previous MOTM winners who wish to enter again (after 12 months) must enter with all new photos of their winning Mazda
* Once you have entered (posted) your Mazda, you may not withdraw from the contest
* The MOTM contest & rules are subject to change in order to maintain a fair & fun environment for the Mazdas247.com Community
ENTRY REQUIREMENTS
* Each contestant must submit three single high-quality high-resolution images of their Mazda. One image must be of the exterior, another the engine bay and finally an interior shot. Compilation style shots (multiple images within a single image or picture size frame) are NOT ALLOWED!
Format
1. Username
2. Name
3. Model name + (Year)
4. ONLY 3 Images (one exterior + one engine bay + one interior shot) NO ATTACHMENTS PLEASE!
5. "Mod" List *Please make your list CLEAR & CONCISE!
Entry Tips
* Wash & Wax
* Clean your interior
* Clean your engine bay
* Choose an interesting location
* Choose a well lit location for photos
* Make sure your interior shot is clear and detailed
* Make sure your engine bay shot is clear and detailed
Example (Obviously, this is NOT my Mazda but for the sake of an interesting example):
Antoine
Antoine *
Mazda 767B (1989)
Performance Mods:
600hp 4Rotor
Exterior Mods:
Aero tuned for the track
Interior Mods:
ALL BUSINESS
Stereo Mods:
4Rotor
Awards Won:
Second in awesomeness only to the 787B
Recognition:
Raced at Le Mans...Helped lay the groundwork for the 787B which won Le Mans in 1991.
PRIZES
* A Mazdas247 T-Shirt and a pair of Mazdas247 Decals!
* Your Mazda showcased on the Mazdas247 Home Page!
* 5% off any Speedcircuit.net purchase made that month!
VOTING RULES
* All voters must have a postcount minimum of a 100 posts. The only exception to this rule is for MOTM participants who are also new members
* There is NO tolerance for PERSONAL CAMPAIGNING threads, posts, private messages (PMs), images or links (including signature and or image links). The creation of such ANYWHERE on or off the Internet including Mazdas247.com will result in immediate disqualification *If you are disqualified, your entry & poll listing WILL remain but your votes will be removed. Everyone will see that you broke the MOTM rules
* Creating GENERAL "Vote for the MOTM" threads and links is allowed and encouraged
GOOD LUCK AND HAVE FUN!
Ritch
Richard Bouchard
Mazda Proteg LX 2000
And since the engine is stock here's an action shot!
Performance Mods:
STOCK 1.8L
HotBits DT1 gravel spec suspension
Exterior Mods:
Light pods
Roof scoop
Mud flap
Skidplates
Interior Mods:
CARS approved roll cage
Oreca harness
Sparco steering wheel
OMP seats
OMP pedals
other rally stuff
Stereo Mods:
Terraphone communication system
Awards Won:
3rd place in P-class at Rallye Saguenay
2nd place in P-class at Rallye de Charlevoix
2.0t03speed
Ryan
Mazdaspeed protege
Engine Mod's:
505Zoom Aluminum Intake Manifold
JayRacing Im & Tb Thermal Spacers
Perrin Fuel Rail
Custom Johnridinhi Grounding kit
JDM Intake Cam
Custom -4AN Oil Feed Line
Custom Adjustable ATP Wastegate
Custom 3" Intake w/ Apexi Filter
GT2871R .64A/R hotside w/ GT28R compact compressor housing
GHL Downpipe
3" under axle Exhaust w/ JIC Magic Muffler & Vibrant Ultra Quiet Resonator
Brushed Air Diversion Panel
CR3 Radiator Brackets
Mishimoto Radiator
Mishimoto Fan shroud w/ dual 12" fans
Signature Products Custom Valve Cover
Signature Products Coolant Catch Can
Signature Products Powersteering Fluid Reservoir
Signature Products vented oil catch can
Custom FMIC w/ 2.5" piping & 30x7.5x3" intercooler
NGR Type-S Bov
Suspension:
C-Tek Rotors Front/Back
C-Tek Pads
D2 RS Coilovers
Hkpro5 Front & Rear Endlinks
Carbing front strut tower bar
Cusco front lower tie bar
Drivetrain:
Exedy Stage 1 Clutch
Karboy Shifter Bushing's
Corksport Exhaust Hangers
TWM Shifter
Medieval Front MM
Medieval Rear MM
Awr Passenger Side Mount
Awr Transmission Mount
Interior:
MSP Production # Plate
Dave B Gauge Rings
Led interior lighting
Forcefed Radio surround w/ real CF Inlays
Alpine XDA-200 HU
Mazdaspeed Shift knob
redline goods shift boot (bride seat material)
Hkpro5 Column pod
8" Kicker Comp VR retrofitted into the stock msp sub enclosure
Exterior:
Retrofit headlights w/ Morimoto mini H1 projectors & 5k 55w hid's
Xcelerated Concepts Reverse Cowl Hood
Xcelerated Concepts CF Trunk
Isport CF Rear Window Visor
nk2a's Sag fix Brackets
JDP Replica Lip
Work Emotion XD-9 17x7.5 +37 front +39 rear
215/45/17 Hankook Ventus V12 evo K110's tires
Work RS black lug nuts
Ems:
Mpi Tuner w/ Extra injectors
J&S Safeguard
Joe P FCD
FM o2 Modifier
GM 3bar Map Sensor
AEM Failsafe gauge
Greddy Profec b ebc
HKS Type-0 Turbo Timer
kloker1994
Shawn
2011 mazda 2
exterior mods:
supertrapp exhaust cat back
hawk racing brake pads
stage 2 racing clutch
Interior:
KENWOOD DDX8036BT headunit
Kicker sound system
underglow under dash
Sparco Pedal Set
1. Domino81
2. Anthony D. Christiano
3. 2008 Mazdaspeed 3
Cobb AccessPort
LexTuned
Cobb SRI and TIP
Sure Return
CP-E FMIC
TWM STS
AutoTech Fuel Pump Internals
James Barone 88-Duro RMM
Forge Version 2 BPV
Koni Yellows
H&R's, Sonic Tuning ST100's 18x8.5 ET48
Cobb Rear Sway Bar
UR Downpipe
CorkSport Race Pipe
Magnaflow Cat-back
BF Goodrich g-Force Sport 235/40/18's
MSD DashHawk
35% tint
Semi-debadged
...Unicorn Jizz
Only int pic I have as of now.
Will have to get better interior pics...
Status
