- 2007 Mazdaspeed 6 Sport
Let's discuss some folks' experiences with autocrossing these cars. I'm sure I'm not the only one interested in getting out on a course and flogging the piss out of this car from time to time. Keep the thread clean. Don't turn it into a pissing match with other users. The goal should be to help others with the same interest be competitive and represent our community well against the other makes and models out there.
With that said, I'll go first!
7/19/2009 - 85 degrees F, clear, sunny weather, 40% humidity
I took it easy my first three times through the course. Just trying to get a feel for what autocross was all about. I was getting pointers from some of the veterans who rode along a few times. On my fourth run I picked up the speed a bit and started to really enjoy myself.
My fifth run I was at full speed. Feeling the monsterous amount of torque this car has and just letting it sing throughout the course at 4500-5000 revs was amazing. However, the amount of understeer my car has is atrocious. There was never any shortage of power.
In fact, I'm pretty sure the power-adders I've done have caused me to outgrow my suspension setup. If I was in the throttle more than 25% while trying to turn I was sliding ride off the course. The massive understeer was very predictable though. Unfortunately it was predictably bad.
Braking was a little bit soft, but there was no fade on the Rotora pads and stock rotors. If I found myself coming too hot into a hairpin, the MS6's brakes would typically bail me out.
I rode with a club autocross veteran and his Mazda 6i through the course. The difference was night and day. That car was on rails throughout. Once put into the bracket, his car proved hard to beat for most everyone else. So I picked his brain to see where I could improve.
It looks as though to get this damned car to turn under power I'm looking at the following:
SPC ball joints
Whiteline 24mm rear sway bar
AWR rear sway bar endlinks
I'm riding on General Exclaim UHP tires without much option to change. For the above runs, however, they had less than 500 miles on them. I will be lowering tire pressure to 42psi at the next run versus 51psi at the above run.
Serv. Desc: 93W Load Index 93 = 1433lbs (650kg) per tire
Speed Rating “W” = 168mph (270kph) Load Range XL
UTQG: Treadwear: 380
Traction: AA
Temperature: A380 AA A
SPC ball joints
Traction: AA
