Mazda How-To Quick Links
Wasn't there a How-To that you or someone else did on painting stock rims?
Correct me if I'm wrong, but it might also be needed to add to the list.
That is correct, I don't see that one on there either. So stealth if you could add these two to the quick links that would be rad. Thanks!
headlight blackout:
http://www.mazdas247.com/forum/showthread.php?t=114394
How to fix curb rash and paint wheels:
http://www.mazdas247.com/forum/showthread.php?t=123668132
Also stealth I think you should rename the "Brake" section to "Brake/wheels" so you can add the curb rash and wheel painting thread there
headlight blackout:
I can't recall if I have already addressed this post or not but thier is already a black out headlight in the list to the same thread.
Also I took note of your suggestion and made the brake to a brake/wheels section. The curb rash how-to has been added as well! Once again thanks for your help!
anyway you can add the 'how to' for detailing and the one for bringing back the shine on yellow?? i'm trying to find that eff'in thread but can't.....GRRRRR
Just added "How to sea foam your engine" under the engine section.
I can't find it either! If you run across it put it in here and I'll add it to the list when I get some time.
Single blub to P5 Headlight Swap
Looking for a "How To" changing the ES single to a Protege 5 dual blub.
Many Thanks.
Many Thanks!! I'll be the first to admit I looked at the diagrams and thought, hieroglyphics.
