toomanybikes
- Mazda 5 sport manual transmission
I have a 2006 Mazda 5 with a manual transmission. About 85,000 miles. Drive it to the office and no obvious problems. Park it. Drive home nine hours later and I'm having trouble getting it into reverse. As I'm driving it home it becomes obvious I am having trouble shifting gears. The clutch pedal feels really soft. I was forcing the shifter into the various gears. (The clutch is original and on the way home I was going up a steep hill and would push in the clutch pedal and pop it out and the car would jerk so I'm assuming that the clutch plate is okay). If I turned the car off and pushed the clutch in I could get into all the gears. To start the car I left it in first gear and when I started the car it started moving forward.
Miraculously I got home and let the car cool off. Symptoms are the same. Looked at my repair manual (Mazda 5 2006 workshop manual, I believe that is the official shop manual) and frankly was not able to follow it that well. It is clearly designed for a trained mechanic which I am not. Nonetheless, the brake fluid in the brake master cylinder was at the appropriate level. I Jacked the car up but did not see any obvious leaking (my theory was that the fluid had leaked out of the slave cylinder. I could not find the slave cylinder but I did not take off the bottom engine cover).
Diagnosis and repair suggestions would be welcome. Thanks
Tom
Rockville Maryland
Tom
Rockville Maryland
