DIY Mazda Firmware Update Information
sm1ke
2022 Mazda CX-9 Kuro Edition
Moderator
Contributor
Canada
PLEASE READ THE POST IN ITS ENTIRETY BEFORE POSTING A REPLY IN THIS THREAD.
To gain access to these files, please DM @Candurin. We ask that you be respectful when you do so. Candurin is a fellow user, and should be addressed as such. They are not a bot. Further, be mindful of your expectations - they may take some time to reply to your message for any number of reasons. Please be patient while you wait for a response. Failure to abide by these requests will result in corrective action, up to and including a permanent ban. Again, be respectful.
NOTE: If you have installed anything like AIO Tweaks, you must uninstall it before proceeding any further with firmware updates. The firmware update will not work with AIO Tweaks installed.
Firmware versions are region specific, so when you send a DM to @Candurin for the links, be sure to specify the following:
1. Your car model
2. Your current firmware version installed (format should be XX.XX.XXX or 7XXXXXX-NAXX_1XXXX or something similar)
3. Your region
IMPORTANT NOTE: These files and processes are compiled from third party sources. Please be aware of the risks of performing these updates yourself. There is some potential to brick your CMU if some steps are missed or the wrong files are used. Mazdas247 does not assume responsibility of the actions taken by its members or the damages that may result from those actions.
These files are being provided as a courtesy to our members, by our own community members, to allow others to avoid the potential dealer fees and time wasted in the dealership, waiting for a technician to perform these updates. Keep in mind that these files and the links that may be provided to you carry no guarantee that they will remain intact in the future.
Typically, most people will perform these firmware updates in conjunction with an Android Auto Apple CarPlay retrofit kit, which can be purchased or ordered from any Mazda dealer. However, these firmware updates may also resolve certain bugs and glitches in previous versions, and may also improve overall performance of the infotainment system.
The most recent, and final update at this time is 74.00.324A. This firmware version/format (.up) will not be installed on new Mazdas. You must use the correct region for your Mazda, as detailed below.
74.00.324A NA N for North America, USA, Canada, Mexico, etc.
74.00.324A EU N for Europe and UK, etc.
74.00.324A 4A N (ADR) for Australia, NZ, Middle East, Thailand, South Africa, Oceania, etc.
APPLICABLE MODEL(S):
2014-2018 Mazda3
2016-2021 Mazda2
2016-2021 Mazda6
2016-2021 CX-3
2016-2021 CX-5
2016-2021 CX-9
2016-2021 MX-5
***UPDATE as of Oct. 2nd, 2024***
The following versions are also available for the '21-'24 models listed below.
7000C0A-NA11_10010 (2024 CX-90)
7000C0A-NA05_11022 (2023 CX-50)
7000C0A-NA10_10004 (2023 MX-30)
7000C0A-NA02_11046 (2022 MX-30)
7230C1A-NA03_10022 (2024 CX-30/Mazda3 w/ NAV - USA)
7230C5B-NA03_10022 (2024 CX-30/Mazda3 w/ out NAV - USA)
7230C2A-NA03_10022 (2024 CX-30/Mazda3 w/ NAV - Mexico)
7230C6B-NA03_10022 (2024 CX-30/Mazda3 w/ NAV - Mexico)
7000C0A-NA06_12018 (2021-2023 CX-30/Mazda3)
7000C0A-NA12_10016 (2024 CX-5)
7000C0A-NA03_11048 (2021-2023 CX-5/CX-9)
7000C0A-NA01_12006 (2021-2023 CX-30/Mazda3 Non-Turbo)
7000C0A-NA04_12006 (2021-2023 CX-30/Mazda3 w/ Turbo)
Once again, to gain access to these files, please DM @Candurin.
Do not post in this thread asking for the links or files. your post may be missed. Keeping track of DMs is much easier. Again, be respectful when requesting update files, and be patient while waiting for a response.
Note that firmware versions are region specific, so when you send a DM to @Candurin for the links, be sure to specify the following:
1. Your car model
3. Your region
Installation instructions (copied from original thread):
Install Procedure...
(All Mazda Models already on Stage 2 .up firmware in use).
IF YOUR MAZDA HAS FIRMWARE VERSION ON or BELOW
55.00.600 NA N for North America, or,
56.00.000 EU N or 4A N for Europe/UK , or Australia, Asia, NZ, Oceania Middle East.
LIKE 31.00.100 or 41.00.000 or 55.00.000 (NA N) or 56.00.000A (EU N or 4A N).
THEN YOU MUST UPDATE with Version Number 70.00.100A First!.
THIS IS A TWO (2) FILE INSTALLATION FOR YOUR REGION or COUNTRY.
70.00.100A-FAILSAFE.UP (First)
Then next Install (one after the other do not remove the USB Flash Drive).
70.00.100A-REINSTALL.UP (Last)
Again, you DO NOT NEED TO Use the Intermediate Firmware of 70.00.100A if your CURRENT Version is 56.00.100 or anything NEWER, that is 56.00.200, 56.00.650, 58.00.240, 59.00.100, 59.00.342A or 70.00.021.
You go straight to 74.00.324A EU N or 4A N.
For North America or NA N the Version change point is 55.00.650 NA N, or Again anything NEWER like, 55.00.753, 56.00.750, 58.00.100, 59.00.770 or 70.00.021
You go straight to 74.00.324A NA N.
Warning...!!!
DO NOT TURN OFF/ON or START ENGINE BETWEEN THIS
TWO FILE UPDATE, you INSTALL ONE after THE OTHER
DO NOT REMOVE USB FLASH DRIVE.
AFTER INSTALL use YOUR ''CONNECT'' in CAR FOR A FEW MINUTES, THEN SHUTDOWN CAR FOR THE LAST FINAL VERSION TO INSTALL.
Next you MUST do final and last below.....
Your FINAL Install Procedure is now Only a 1 (one) File Installation...
(All Mazda Models with .up Firmware use)
IF YOUR MAZDA HAS .up FIRMWARE VERSION ON or ABOVE
55.00.650A
(NA N) or the 56.00.100A (EU N or 4A N) or 58.00.310A
or Any 59.00.502A or 59.00.650A,
or Any 70's Firmware like 70.00.021A, 70.00.100A or 70.00.110 or
70.00.150A or 70.00.335C or 70.00.367A or 74.00.230A or 74.00.311A
THEN YES YOU CAN UPDATE Directly to 74.00.324A for LATEST FIRMWARE.
This is now a SINGLE FILE (1) ONLY INSTALLATION for
YOUR REGION or COUNTRY,
MUST USE EITHER ONE of...
NA N_74.00.324A-UPDATE.UP (North America ONLY)
or
EU N_74.00.324A -UPDATE.UP (Europe/UK)
or
4A N_74.00.311A-UPDATE.UP (ADR, AU. NZ, ME, Asia) (74.00.324A 4A N (ADR) is not yet available)
THIS IS THE LATEST GENUINE FIRMWARE CURRENTLY AVAILABLE
FROM MAZDA JAPAN As Of December 30th, 2022.
ALL 7x.00.xxxx FIRMWARE INCLUDES the Software for
CAR PLAY + ANDROID-AUTO....But...
For the CP/AA CONVERSION TO ACTUALLY WORK IN YOUR MAZDA
You MUST HAVE THE TWO ''GENUINE MAZDA PARTS'' INSTALLED
AFTER any 7X.00.XXXX is installed and or WORKING in YOUR CAR FIRST.
THERE ARE NO SHORT CUTS or OTHER BRAND PARTS...None, DO NOT ASK.
YOU MUST PURCHASE and INSTALL the TWO GENUINE MAZDA PARTS LAST.
DO NOT INSTALL THESE NEW PARTS FIRST or BEFORE ANY 70s FIRMWARE OTHERWISE YOU WILL HAVE TO REMOVE THE NEW PARTS RE-INSTALL THE OLD PARTS AND THEN START AGAIN.
YOU CAN NOT SEPARATE THIS CARPLAY and or ANDROID-AUTO
AS THEY ARE BOTH INSTALLED WITH all 7x.00.xxx FIRMWARE.
CARPLAY and ADROID-AUTO WILL NEVER WORK WITHOUT THE
TWO ''GENUINE MAZDA PARTS'' Finally INSTALLED Last...PERIOD.
Regarding wired and wireless AA and ACP, please be aware that Mazda only supports the wired aux hub and two large USB cables for Carplay and/or Android Auto conversions.
Genuine Mazda CP/AA wireless is only obtained by using an updated "Wireless CMU" (the inside dash hardware) and the updated aux hub.
Mazda does not sell or support wireless CP/AA via a "dongle." These "dongles" are not from Mazda nor can they be considered a genuine Mazda part. They are sold on Amazon, eBay etc. Quality and longevity is an unknown compared to OEM solutions.
I just completed this today for my 2018 CX-5 running on 59.00.504. I PM'd @Candurin who sent me links to both files I needed to jump to 70.x and then to 74x. I was very patient and followed the procedure carefully. I'm planning to install my https://www.amazon.com (commissions earned) tomorrow.
Thank you for this post and prompt reply to my request for the files!
Amazon wireless carplay works great. Very easy to install based on YouTube videos to pull out the trim pieces. I routed cables from the top to back.
To be clear, according to the post instructions, if you're running any firmware newer than 55.00.650A then it should be a single file update, no?
I got my friends into a 2018 CX-5, and am going to help them install CarPlay. I can confirm jumping from 59.00.65A to 74.00.324A was a single file update, with no failsafe package install, as was stated in the OP. Thanks for the detailed instructions!
Yes my CX-9 was on 59.xx.xx firmware and I did the single file update. I think you can still do the upgrade to the failsafe and the final upgrade safely, even if your firmware version is on or above 55.00.650A (NA N) or the 56.00.100A (EU N or 4A N). For those newer versions, you simply have the option to do the one file upgrade if you wanted to.
I just updated to version EU 70.00.100A. Will I still be able to update the version after installing the carplay module, or do I have to update to the latest version first?
I think you should update to the latest version first, just to avoid any potential mix ups
I have a Mazda CX-5 Grand touring 2021
Firmware is at 11022
Located in the USA
Could someone help me with a link to download the latest firmware. I believe it is NA03_11048. Not sure about that one.
Located in the USA
If you haven't heard back yet:
To gain access to these files, please DM @Candurin. Do not post in this thread asking for the links or files. your post may be missed. Keeping track of DMs is much easier.
1. Your car model
2. Your current firmware version installed (XX.XX.XXX format)
3. Your region
Sorry for posting it here but @Camdurin does not have the latest generation software. At that point unsure who to PM. I know there has been some exchange for the latest version from the comments.
Does anyone know if you can change region by updating the OS? I have a Japanese car but would like to update to AU/NZ version of the OS.
Can I overwrite / install the different region.
Current is:
70.00.110 JP M
