Mazda CX5: feel slight vibration in gas and brake pedal when AC is on
Hello everyone,
I am just wondering if anyone else has this issue. I have a 2023 Mazda CX5 Select. I can feel a slight vibration when travelling at slow speeds, and when stopped when I have some load on either the brake or accelerator pedal. I don't have to have the pedal pressed all the way, but I can feel some vibration, although it is very slight. I have found the vibration is only there when the Air Conditioning is on. Has anyone else noticed this? Is this something normal or a known issue, or is something wrong with the A/C compressor or engine?
Cheers,
Biz
I have also noticed that the idle dips low when the A/C compressor cycles on, and have seen several others mention the same, so it's not just your car.
up until 2025 models, Mazda uses a non variable AC compressor.
"Normal operation of a car's AC compressor might involve a slight shudder or shaking, particularly noticeable at idle, as the compressor engages and places an additional load on the engine
. This is because the AC compressor, essentially acting as a miniature engine, requires power from the car's engine. When the compressor kicks in, the engine's idle speed may drop momentarily, resulting in a slight vibration"
The topic has been discussed before if the OP is interested:
Wow, thank-you very much!
"up until 2025 models, Mazda uses a non variable AC compressor"
So how does an variable compressor differ in operation?
