I've had my CX-60 for a month and half the time it randomly stops charging overnight at 10, 11, 14%.  Dealer is seeing it soon but have said unless they see it themselves they won't class it as a fault...Any suggestions?
			Yes, replacement of the charger (the blue charging cable), it's a well known issue, after replacement all problems should go away.I've had my CX-60 for a month and half the time it randomly stops charging overnight at 10, 11, 14%. Dealer is seeing it soon but have said unless they see it themselves they won't class it as a fault...Any suggestions?
@CX60 Driver Just wondering if you've had any luck with changing the charge cable at all. We're having a similar issue where we set the car to charge using the schedule from midnight to 5am, get a notification to say charging has started and 2 minutes later or half an hour later get another to say that charging is complete. Remote charging won't initiate either as the car now thinks its fully charged. Any info would be much appreciated!I've had my CX-60 for a month and half the time it randomly stops charging overnight at 10, 11, 14%. Dealer is seeing it soon but have said unless they see it themselves they won't class it as a fault...Any suggestions?
My dealer said it wasn’t the cable but the software and did a software update. It reduced the frequency but didn’t stop it.@CX60 Driver Just wondering if you've had any luck with changing the charge cable at all. We're having a similar issue where we set the car to charge using the schedule from midnight to 5am, get a notification to say charging has started and 2 minutes later or half an hour later get another to say that charging is complete. Remote charging won't initiate either as the car now thinks its fully charged. Any info would be much appreciated!
I have cx60 may23I've had my CX-60 for a month and half the time it randomly stops charging overnight at 10, 11, 14%. Dealer is seeing it soon but have said unless they see it themselves they won't class it as a fault...Any suggestions?
@MikeLisboa Please explain how to reduce the setting…After the latest software update, I had one occurrence of the car stopping charging after less than an hour. I have found that in a commercial charger, I get back up to 62 KM of charge and at home have gotten up to 57KM of charge. I reduced the charge from 100% to 90% and that seems to have increased the capacity I get from home charging. Things are improving and the energy management is improving. I’m actually getting the mileage displayed in the capacity more regularly. The I’m pleased with the fix.
I have had my cx60 about a month. I have this problem. My cable is connected through a wi fi plug. When the car app tells me the car is charged after half an hour, I switch the power off then on, it always charges fully after that.I've had my CX-60 for a month and half the time it randomly stops charging overnight at 10, 11, 14%. Dealer is seeing it soon but have said unless they see it themselves they won't class it as a fault...Any suggestions?
