Mazda 626 GE FP
Lukas007
626 GE FP / Probe GT F2T / E34 M60
MAZDA 626 GE
Hello everyone! My name is Lukas and I live in Poland, I want to show you my car. Have a look on the description and few pictures and feel free to share your opinion about my ride.
SEASON 2007/2008:
I want to show you my Mazda 626 GE with E-SPEC 4 cylinder engine (1.8). Mileage is now about 140 000 miles since 1992, when the car was produced. On stock engine it has got 105 BHP and 155NM. With few modifications I earned 125BHP and 170NM, proven on dyno. I never want to change anything outside, as you can see I kept my word. The only changes are: 16" wheels with TOYO T1-R tires, 6000K HID lamps and clear side indicators - that's all. Every other thing outside is fully original. Steering wheel from 2 gen MX-6 was my favourite one since I first saw it. In this case I decided to buy it, then to cover it with a two-color leather. I must say that I'm realy satisfied with the result. With leather shift knob and chrome rings around gauges, it make my interior unique and IMO not exaggerated over stock. Audio is quite good so I left it stock, except a new Alpine CDE 9850Ri radio. I also upgrade my brake system. Quick Stop Pro drilled/slotted rotors with Posi-Quiet pads are very enought for 125BHP and 1140kg (2500 lbs). For last season my suspension setup was leaning on Eibach Pro-Kit springs with stock KYB struts (gas on front and oil on the back).
SEASON 2009:
For new season I've changed my suspension for Sprint springs on Tokico Illumina struts. I also painted my valve cover in gloss black colour. Engine is now on 5W30 MOTUL Power Racing oil. Interior lightning was improved with V-Leds "cool blue" leds. There is also important change in transmission - Fidanza SS - witch makes a lot of difference compare to the OEM one. A litle cosmetic was done to the exterior. I removed orange filter from front and side indicators. Original orange bulbs were replaced with special, chrome ones.
SEASON 2009 - new ideas:
Later this year I decided to make my modifications a bit... more visible. I bought new set of rims and tires. Kosei K1-TS in 17x7 size with Hankook Ventus V12 Evo 205/45R17 tires. But when I put them on I wasn't very satisfied. They're beautifful themselves, but they don't realy fit GE body. So I decided to buy new wheels - Enkei rims from Lancer EVO IX. With 205/45 Hankkok tires they make my car look sick IMO. Perfect width and offset without spacers and other crap. Brakes are different too: Mazda 6 3.0 V6 sized rotors from KVR (J-Hook in silver plating), and stock sized rotors, in the back, but also from KVR (J-Hook in silver plating too). Of course front calipers are dedicated for OEM Mazda 6s ones. I've chosen EBC Red Stuff brake pads for both axles. Stock brake lines were replaced by Corksport SS ones, and filled with sport MOTUL RBF 660 fluid. My suspension setup is leaning on Sprint springs and Tokico Illumina struts. Next year I will change this springs for stiffer Megan Racing product to increase handling. I'm planing to get a rear strut bar too. After almost one month in body shop I have my car with new shiny paint, without andy dents or schratches. Some mods were made in interior. Original shift knob was replaced by Greddy Counter Weightned one. It fits perfectly and, because of its increased weight, makes shifting with Fidanza SS even more fun. I have also changed my intake system for CAI. I haven't check it on dyno, but comparing to BMC CDA airbox, this operation was worth it, esspecially if you're talking about sound.
SEASON 2010
For this year I improove the car audio system, add 10mm spacers on front and rebuild the CAI intake system. Let's begin with the stereo. Speakers panels are shaped to fit the 6.5" Helix RS3 Competition woofers under the custom made grilles. Tweeters of this passive system are now placed on the A-Pillars. Crosovers are placed in the trunk with the DLS A5 amplifier, Helix capacitor, and JL Audio 10W3v3-4 subwoofer. All car, so - floor, trunk, doors etc ... is sound dampened with Dynamat Extreme. Head unit of this system is Alpine CDA 9835R. All this stuff is connected together with Eagle cables. Not forget to mention that the battery is moved to the trunk, mainly because rebuilded CAI system, which is my 2-nd mod of this year. Last, and only one that made the difference outside, is a set of Ichiba 10mm spacers for front EVO IX wheels.
SEASON 2011
This year I decided to add some power to my engine. First off all, the stock FP bottom was replaced by FS one (2l, 9:1 comp, 85mm bore, 93mm stroke). The second step was to fit a set of FS-ZE pistons (10.4 comp) inside it. After that, inside my already ported head (FP and FS had the same engine heads), we placed both - FS-ZE intake camshaft and Corksport exhaust camshaft. For now engine ECU is not yet tuned on ECU Master DET II piggy'back (which was installed almost 2 years ago), so for now I'm driving on old fuel maps and old inginion settings. Probably next month I will find someone who will set up my ECu correctly, and then, I'll be able to post some dyno resoults.
What is worth saying, both FP and FS have the same compression ratio but different stroke. Because of theirs same bore you can use FS pistons in FP to decrease compression or use FP pistons in FS engine to increase it.
... my movies are here -> YouTube - lukas626's Channel
Modification list:
ENGINE:
  1. SWAP for FS engine (e-spec 115BHP)
  2. JDM FS-ZE pistons (10.4:1 compression)
  3. JDM FS-ZE intake camshaft
  4. Corksport exhaust camshaft
  5. Modified cylinder head (porting)
  6. CAI system with Simota filter
  7. 2" exhaust - two mufflers and high-flow cat
  8. Custom 4-1 header
  9. NGK spark plug wires
  10. NOLOGY Silver spark plugs
  11. Outlaw Engineering spacer kit
  12. ECU Master DET II piggy-back
  13. ELF Evolution 5W30 oil
SUSPENSION:
  1. Sprint springs
  2. Tokico Illumina struts
  3. New front/rear strut mounts
  4. New strut boots
  5. Front S.S strut bar
BRAKES:
FRONT
  1. Mazda 6 3.0 V6 sized rotors from KVR (J-Hook silver plated)
  2. EBC Red Stuff brake pads (for OEM Mazda 6 3.0 V6 calipers)
  3. Silver painted stock calipers from Mazda 6 3.0 V6
  4. Corksport stainless steal brake lines
  5. MOTUL RBF 660 racing fluid
REAR
  1. OEM sized rotors from KVR (J-Hook silver plated)
  2. EBC Red Stuff brake pads (for OEM Mazda 626 GE calipers)
  3. Silver painted stock calipers from 626 GE
CAR AUDIO:
  1. Head unit - Alpine CDA 9835R
  2. Front - Helix RS3 Competition - passive system with 2-way crossovers
  3. Rear - no rear speakers
  4. Subwoofer - JL Audio 10W3v3-4
  5. Amplifier - DLS A5 "The Big Three"
  6. Sound dampening - Dynamat Extreme / Brax eXvibration / Dynaxorb
  7. Capacitor - Helix DPC 1000
  8. Cables - Eagle cable / Caliber
INTERIOR:
  1. Mazda MX6 leather steering wheel
  2. Greddy Counter Weightned shif knob
  3. Silver rings around gauges
  4. V-LEDS interior lightning - cool blue
  5. Gray floor mats
  6. Custom woofers grilles al'a Efini
  7. Leather covered, custom shaped a-pillars - for tweeters
EXTERIOR:
  1. New pain on whole car (stock colour)
  2. Well-Done HID 6000K
  3. V-LED SMT5 parking lights
  4. OEM fog lights with yellow bulbs
  5. 17x8" ET=38 Enkei wheels from EVO IX
  6. Hankook Ventus V12 EVO tires (205/45)
  7. Ichiba 10mm spacers on front axle
  8. Clear side indicators with chrome bulbs
  9. Front indicators w/o orange filter with chrome bulbs
  10. Oval exhaust tip
Pictures:
Greetings
Lukas
Thanks mate ;)
New wheels from Lancer EVO IX - Enkei 17x8 ET=38
New car audio components...
To Be Continued ...
Greetings
Lukas
Hello Lukas,
Thanks for posting up your car! I was wondering what it looked like after all those emails.
-Derrick
I want those brake rotors! I love that slot design, almost as much as dimpled rotors. Beautiful car!
Hi Derrick ;) ... those e-mails, and informations that I've recieved from you were very helpfull and I want to thank you for that. I hope that my car didn't dissapoint your expectations.
JC-MP5... those rotors are awesome indead... I wasn't pretty sure about them but when I first saw them right after they arrived - I was amazed. High quality from KVR (silver plated works - no rust after 2 months, even in strong rain and many washes) and perfect design of the new "j-hook" slots. They're also very effective when it comes to braking. With EBC Red Stuff pads (very loud but also very strong grip) they create a perfect combination of looks and performace. The only minus of bigger rotors is their weight - almost 6lbs heavier than stock ones - the acceleration is a little bit poorer...
Next mods comming up. Widening the front axle with 10mm spacers (rear is already "in line" with the fender) and coilovers to make this baby stance like heaven. Car audio install should be done until march, but because of the new suspension it may take a bit longer...
Greetings
Lukas
I bought a set of spacers for the front axle to make the stance better. While the rear wheels 38ET is perfectly matched to the GE fender, the front one is slightly to high now ... maybe because of slight negative camber, maybe just because of the front fenders shape. Now, with those 10mm on each side, the front offset will be 28ET and the wheels should stay equal with the fender line ... I think that wheel ET is as important as the lowering itself. It's nothing worst than a lowered car with tucked wheels fallen with giant fenders because of their huge ET.
Ichiba spacers pics:
Some pictures after instalation
New suspension will have to wait until I finish my new car-audio setup.
Greetings
Lukas
car looks real good, wish my 626 looked like that!!!!!!!
Thanks msp5
Updates
New stuff for my CA setup ...
Sound deadening
Change of plans. We decided to put a high-end Helix RS3 competition front system instead of Rockford's T1652s ... here is a little comparision
Speaker panels ...
A-pillar custom made for Helix tweeter
Trunk set up ...
New amplifier for the whole system - DLS A5
Almost finished trunk setup ...
Finished car-audio setup
Thanks ;)
New stuff
During the install...
Sound video
<iframe title="YouTube video player" class="youtube-player" type="text/html" width="640" height="390" src="http://www.youtube.com/embed/klpyckyf00I" frameborder="0" allowFullScreen></iframe>
Great Car
Wow!!! Absolutely the best 626 I've seen on this forum thud far. Your car is what I hope mines will one day be. Im still at the basics right now in just trying to get simple parts for my 626. Your light years ahead of me. Great Car.
I haven't been updating this thread for a long time, so ... new stuff.
Dyno
Videos
