mazda 6 homelink mirror(2007)wiring
bignaz
hello everybody,(headbang)
i am retrofitting a homelink mirror to my 2010 cx9. the mirror i have was
from a 2007 mazda 6(so i was told) the connector to the mirror is a 2 row, 10
pin connector. has anyone done this or can anyone give me the wiring
diagram for the hookup. i do not have a wiring harness for it. if anyone has a
harness for this please let me know.
thanks.(smash)
naz1399@aol.com
Take a look in the how to section here, I put a Homelink mirror into my MS6 and wrote it up. It won't match up with what you have, since the wiring will probably be different, but you can see in there how I wired it int the car so that should give you some ideas. I don't have my wiring handbook handy now, loaned it out to someone so they could try something, but I don't recall if the mirror was in that in any case.
In the end, you just need three wires, odds are the Homelink connector only is using those if you look at it. If the coloring is the same as it was in my harness then you're set (maybe). Your other option is to order the wiring harness from a dealership, it's only $25 and in your case it might be the best option to wire it into the car properly.
