Seems I've hit on something here...
I'll check it out more closely in the next week or so and see if I can locate it.
I too thought it might be the windshield but I'll press on parts of the dash while someone else drives and see what I get. I have pretty good ears being into sound for a living so once my head (ears) are close to the source I should know better, hopefully. I'll bring this up with a dealer also and post the results.
I find it quite sharp sounding sometimes and it can really get your attention, so that implies to me that it may be something under tension. ie; dash components fit - which would change and beccome more of an issue in the cold. Could be windsheild also since that too is under flex tension.
I wouldn't bring it into a dealer in the cold as they would likely break something and not tell you, then we would be worse off than before.
If anyone knows for sure, please post! I'm determined to fix this!!
Thanks,
G
