mazda 323gsi fault on tcs
mazda 323gsi
Have a 323gsi 2000 model year. tcs light displays off . I have checked pin data at abs module and pin "p" reads zero volts with ign on and tcs master switch in both on and off position. Anyone any ideas as to where the feed to switch is received from or other reasons for lack of feed. If any help the dlc also doesn't seem to work when fault diagnostic when bridging gnd - tbs any fault should be shown by flashes but when I bridged them the abs and tcs light remained lit. I suspect a fault on the offside rear abs sensor after checking all the pin data but the tcs light was on long before the abs. any help guys much welcome
