Hows it going everyone, so these are my symptoms will be driveing hit -8psi go into closed or open loop cant remember but im at 10afr then I get to 0psi and im at 12.3 afr, hit boost start leaning out to 13 afr then jump back to 10afr release gas and instead of seeing the ----- on the guage i might see 17afr then hit the gas be at 16afr and droping fast to 14.5afr. which is where I should be. Idle's fine. Pulled plugs starting from left to right 1st sooty half way has gloss looks wet, 2nd clean, 3rd and 4rth sooty half way. Running denso 1 stage colder. obviously the clean one is my concern. idled car started pulling cables they where all getting spark got shocked a couple times. so you think its coils maf pump injectors? I rotated the coils and got the same result. Will be putting regular plugs back in tommorow.ngk.stocker.
