I went the valve seal route, because oil would get into my cylinders while the car sits and cools down.
Could oil make its way up through the the rings with the car off while it cools down?
Is there a vacuum in the cylinder that could suck the oil up? That explains why I get less oil when accumulation when I remove the plugs while hot.
Can rings fail on one cylinder only? I done a compression test and everything seemed to be fine. I'll look into the leak down test too.
