MAP / MAF Question
Brannon9827
2003 Mazdaspeed Protege
My car is hitting fuel cut at 10psi, so I went out and got a fuel cut defender from Split Second. Now the directions say to connect the wires to the MAP sensor, if you do not have a MAP sensor then it needs to be connected to the MAF sensor. Well I know for a fact that we have MAF sensors on these cars. Now do we have a MAP sensor as well? I have located what looks to me like a MAP/Barometric pressure sensor. This is under the hood on the passenger side up against the firewall. I have done a little bit of research and some say we do not have MAP sensors and others say we have both MAF and MAP sensors. Does anyone know which it is?
Our cars use a MAF and a Barometric Pressure Sensor. Passenger corner of the engine bay, near the firewall.
