Magnecor Wires for MSP?
t3ase
Banned
Contributor
Tonight I switched out the spark plugs on the MSP and noticed how small the stock spark plug wires were. They do need to be replaced but due to several problem related threads about Sparco wires, I'm trying to find some made by Magnecor. I've looked around for some, but haven't found any. Then I found the official Magnecor catalog which shows:
2003-2001 Protege (except 2003 Mazdaspeed Protege) 40413 47300 45300
Does anyone know what set I should get? Also, what width should I be looking for? I read somewhere that wires come in like anything from 6mm to 12mm depening on application. Any suggestions?
magencor is stupid
the wires that "weren't made for the mazdaspeed protege" WILL fit into your msp... the whole ignition system is the same... even the damn stock wires are the same
I love your "I HATE THE WORLD" attitude. :D Thanks for the help.. I emailed them before you replied so we'll see what they say about it.
the wires will do you absolutely no good - bought a pair, installed them, sold them. zero performance value. they only replace two of the four wires, and as theMAN so eloquently put it "the whole ignition system is the same... even the damn stock wires are the same". the protege's ignition system is coil-less direct fire is it not? forgive me if i used the wrong terminology.
in short, don't buy them, they are waste of hard earned cash unless you go for the half-red half -black look on the valve cover.
i have magnecor cables in my MSP is the same of the p5 or regular protege is only two cables 6.5mm work fine im put when the car is new and at this moment have 8k miles in the odometer
without any problem
att IRR
1239/2000PR
