LTFT B1 issue
joeylow
2008 MAZDASPEED3
using my dash hawk im getting -11ish ltft b1 i checked all my couplers on the charge piping (protege garage kit) made sure piping was in the coupler good and clamps were tight, cleaned my MAF. took the car for a drive now its reading -17.4. anyone have any idea what it might be.........cpe sb and pnp removed and cobb ap tune stage 2 cai installed
MOD LIST
AEM CAI, Turbosmarts BOV, Vibrant Exhaust, H&R Springs, AWR Motor Mount, Evotion Turbo Timer, Corksport Downpipe, MSD Dash Hawk, PTP PVC Fix, PTP Fuel Pump Kit, Protege Garage Intercooler Kit, DEI C02 Sprayer, CP-E Standback, CP-E PNP Harness, Prosport Vent Gauge Pod, Autometer Boost Gauge, N2MB WOT Box/ 2Step Launch Control, Denso Iridium ITV22 Spark Plugs, Prosport Sandwitch Plate, Filter Conversion Kit, Mazdaspeed6 Wheels, 5mm Spacers, BF Goodrich G-Force Radials 225/40/18, Twin Supertone Hellahorns
Is this while car is moving or at idle? LTFT b1 will change due to weather or time of year. My tuner said -11 is nothing to worry about at idle. On my car I have seen it stay at -7 to -14 at idle. If your car is working fine and no codes are popping up then might want to get a tune.
its at idle today it is reading -18.2 goes down when driving and reads 0.0 at wot, i have had to clear a wastegate code 3 times now over the passed 3-4 months
It's kinda hard to tell because you are not in the danger zone (+25%/-25%) and throwing any codes related to this. And with what you have posted there shows car is running fine but a bit lean at idle. It could be a faulty MAF sensor or low fuel pressure. More likely a fuel delivery problem. But like I said it's not really a problem until you see fuel trims in the danger zone. I would just keep an eye on LTFT for now.
