lsd bearings.
Pez
2003.5 Mazdaspeed Protege
I just wanted to state that getting this bearing off the old lsd gear side is a p.i.t.a. so if anyone decides to do this make sure you got some dremmel cutting disc or a puller small enuff to fit in there. Thanks for listening to my rant.
yeah, a full machine shop helps lol. i did my whole dismantling of LSD, ring gear/drilling out rivets + adding to new diff / all bearings+races in about 5 hours. a lot of work if you do it all yourself
Ihad the trans pulled.and split in no time. Went to some shops during the weekend and got the run around from all of them. So I just took it to work today and did all the drilling at work. Couldnt get the bearing off so I brought it back home after work and went to town with the dremmel. Now I gotta take it back to work tomorrow and press on the bearings and torque the gear down and ill be able to put everything back together.
