Lowing Question
Tigheb
Mazda 3i
I have a Mazda 3i and just want to lower it like 1.25. I was looking at the Eibach Pro-Kit. My question is should I get the camber kit for the +/- thing and tire wear? Will they install them when they put thre springs on?
Also if I am missing something LMK.
Thanks
you can usually get away with just an alignment with a drop that low, i got an alignement and have kept up rotating my wheels and have had no unusual wear and they were able to get it back to the factory spec on camber and toe.
i dropped my 3 about 2.5" and i only had a smaaaall camber difference. the wear was definitely not that bad. i think that with that small of a drop, you should be fine. although with any drop, you should get a new alignment, because it could effect your tow. so it wouldnt be a bad idea.
Lowering the car shouldn't have any affect on the toe.. it will change the camber and caster though, maybe the rear toe..
