Lowest Wheel Offset??
RCC
I'm going to change the wheels on my 2000 Protege LX in the spring (Maybe sooner if I find a good deal). What is the lowest offset any of you guys are running with a 15" wheel? Stock is 45et but I'd like something that sits out a little more. Picture would be great too.
Thanks
I was running 17x7.5 +45...looks flush.
Offset depends on the width of the wheel and the tire size you get.
im running 40mm on my 17x7's...
it is the absolute flushest possible without rubbing...
I'll have to co-sign on that. I had 17x7 40mm on my 2000 Protege and it was completely flush. It depends on tire size as well. I would rub slightly with 215/40/17 so I switched to 205/40/17 with no rubbing at all.
215/45/17 with 38mm offset
slight rubbing on the front left when it's fully compressed.
fenders rolled
