Looks awesome.
Handling is improved a lot (wider wheels too). I can take high-speed turns without decelerating, and maintain traction while accelerating through them, 80+. Or another example is at a multi-lane intersection, I can easily turn left while accelerating at a speed at which other cars are usually cutting into the inside (left turn again) lane, enough to block them. It's kind of hard to describe without "track" numbers I guess. Stock dampers are holding up well; at least 18k on them since my car was lowered. I have a slight "wheel hop" while accelerating hard in a turn from low speeds, usually if the road I'm on is garbage, but again that's not really "normal" driving, and if adjustable tie-rods become available cheaply state side I would probably use them (currently only offered as JDM). Until then it's not even remotely a real issue.Looks good ChrisTopHer. Now that you've put a few miles on the setup, what's your observations on ride quality/handling?
How are your tires wearing?Handling is improved a lot (wider wheels too). I can take high-speed turns without decelerating, and maintain traction while accelerating through them, 80+. Or another example is at a multi-lane intersection, I can easily turn left while accelerating at a speed at which other cars are usually cutting into the inside (left turn again) lane, enough to block them. It's kind of hard to describe without "track" numbers I guess. Stock dampers are holding up well; at least 18k on them since my car was lowered. I have a slight "wheel hop" while accelerating hard in a turn from low speeds, usually if the road I'm on is garbage, but again that's not really "normal" driving, and if adjustable tie-rods become available cheaply state side I would probably use them (currently only offered as JDM). Until then it's not even remotely a real issue.
I know others have lowered.. add your car here!
Damm it Eibach, bring the pro-kit state side!
Still "green" after about 20k and hard driving. I've rotated the tires twice, well swapped left front with left rear. I can only swap sides if I were to remount the tire.How are your tires wearing?
No more lowered CX-5s, what happened?
Chris, with your drop since it's so low I can't tell the difference from a 2014 3 series.
pic of stock suspension CX-5[IMG]
[/B]
[B]No drop yet[/B]. Looking for 1" drop to accompany the 19" rims/tire.
Damm it Eibach, bring the pro-kit state side![/QUOTE]
"Lowered CX-5 Appreciation Show me your drop!"
Wut.
What did you hit to bend a rim?I have my stock (19") tires on atm because one of my wheels was slightly bent.
