Low Speed Brake Noise with EPB - Need Advice (Medellín Colombia)
2016 Mazda CX-5 Low-Speed Brake Noise with EPB – Need Advice (Medellín, Colombia)
Hi everyone,
I’m reaching out for advice on a persistent issue with my 2016 Mazda CX-5 (manual transmission, 100,000 km), which I bought used in Medellín, Colombia. The vehicle has an electric parking brake (EPB) and a VIN of JM8KE2W79G0331455.
Since I got it, I’ve been dealing with an intermittent low-speed brake noise (a groaning or friction-like sound) that seems to come from the wheels, sometimes from the front and sometimes from the rear. I’d really appreciate any insights from other CX-5 owners, especially those familiar with EPB issues.
Details of the Noise:
The noise has the following characteristics:
1. It only happens at low speeds (e.g., 0-15 mph), especially when starting to move or driving slowly, as if it’s tied to the wheel rotation.
2. It’s intermittent – it doesn’t happen every time the wheels turn, but occurs in specific low-speed moments. The sound lasts about 1 second, stops, and may return after 3 seconds.
3. It sounds like friction or a groan, similar to metal rubbing. When it was more intense (before rear brake maintenance), it seemed to occur with every wheel rotation.
4. The noise is more noticeable when I release the clutch after shifting (1st or 2nd gear), but it also happens without clutch engagement at low speeds.
5. It sometimes appears or gets louder when turning the vehicle, though not always.
6. The noise is more pronounced with extra weight (e.g., when multiple passengers are in the car).
7. It seems to increase when the car is in neutral and coasting.
8. Key detail: The noise seems to temporarily disappears when I activate and deactivate the electric parking brake (EPB), but it returns.
Previous Repairs and Temporary Fixes:
I’ve taken the car to mechanics three times, with temporary relief each time:
1. First visit: They cleaned the rear brakes, and the noise disappeared for 2 days but returned.
2. Second visit: A mechanic noticed the front right wheel had some resistance. They replaced the front brake pads (which were worn), and the noise went away for 2 days but came back.
3. Third visit: The noise seemed more noticeable from the rear. They filed down part of the rear brake pads, which seemed to be causing the issue, and the noise stopped for 2 days but returned.
4. Most recently, the noise came back (less intense) when driving with multiple passengers.
Questions for the Community:
1. Has anyone with a 2016 CX-5 (especially with EPB) experienced a similar low-speed groaning noise tied to the parking brake? How did you resolve it?
2. Could the EPB module need a software update (per TSB 04-005-16-3217), even if my VIN (JM8KE2W79G0331455) might not be covered?
3. Is rust on the rear rotors a common issue in humid climates, and would resurfacing or replacing them fix this?
4. Should I insist on checking the rear calipers for sticking or improper retraction, given the EPB’s role?
5. Any other TSBs or recalls for the 2016 CX-5 brakes I might have missed?
Thanks in advance for any help or suggestions! I’ll update this thread with what I find out from the dealer.
Do this test….
Stop the car. Keep the engine running and car in gear.
Apply the park brake.
Without releasing the park brake, drive off. The park brake should automatically release as the car begins to move.
If the car pulls to one side when the brake releases, then its a known manufacturing problem with the electronic park brake and was subject to a recall/technical service bulletin (TSB) issued by Mazda back then.
While one would think it should have been fixed on your car by now, perhaps it hasn’t been. You can go to your Mazda dealer explain the above test you did and the results and ask them to check if its covered by the TSB and if so it should be eligible for repair at Mazda’s expense.
Do this test….
Moonlighter,
I performed the test as suggested: Once I started accelerating, the park brake released very smoothly without pushing the vehicle in any direction, and there was no pulling to one side.
Since the car didn’t show this issue, can I safely rule out the known electronic park brake (EPB) manufacturing problem that was part of the Mazda recall/TSB? Thanks for your response and help!
Moonlighter,
Well, thats the test they specify to be done in the TSB. When my CX5 had the issue, it would definitely pull to one side, the dealer tested it and as soon as they verified it they then booked it in for rectification.
So I would personally think that you’ve ruled this out as the issue.
Assuming you're confident it's not the EPB, I would check the wheel bearings, although it does sound braking related.
