Protege_MP3_506
- 2001 Mazda Protege MP3
So I was gonna take the msp to my mechanic and have him change the main crank seal (front) cause its leaking pretty bad. After looking at the car a little he told me he wasnt gonna fix it because it would just go out again. He pulled out the pcv valve and the dipstick and it was blowing out a lot of oily air. He said its most likely my piston rings that are fried. The car only has 78k on it but i guess if it was beat to s*** for that amount of time it is very possible. The car does smoke (white) when i sit there and let it idle for awhile and it will randomly do it when i am driving down the road, not necessarily just when i'm getting on it. I heard if my rings were bad it should be blue smoke right? Isnt white smoke headgasket? I'll drain the oil when i get around to it and see if the antifreeze is mixed in with it. Also makes a non stop squealing noise but i think it might just be one of my pulleys. Car still boosts up to 6lbs perfectly, does smell like it is burning oil when i do push it hard. I found a used motor off a p5 for 400 locally. Just a few things i would need to swap over right?
