There was a just a thread posted a couple weeks ago that addresses some of your questions:
http://www.mazdas247.com/forum/showthread.php?123855013-On-the-market-for-a-2012-any-buyers-tips
I would start with with KBB and Edmunds TMV as a base for pricing.
Prices very by market, hard to go by forum.
I'd sell you mine 2012 for $10000k with half that millage but va is a bit far from ca although import is easy![]()
What sort of major maintenance items should I be worried about? What common problems occur?
Thanks for your help
Would that be $CAN, or $US?
Here are some of the issues I've seen on this forum:
1) suspension wearing out - specifically, the older sway bar bushings wearout and cause an squeaking noise - other people have reported other rubber bits wearing out. The struts and shocks also seem to wear fairly fast.
2) Rust - seems to be a Mazda problem - I don't have this issue in California
3) Transmission - change your fluid often - original transmission fluid seems to wear out ~30-40k miles and can lead to other problems
4) Tires wear out fast - specifically, some have issues with uneven wear on the rear due to the factory camber settings (the inner part of the tires wear before the outer
5) Brakes - some experience fast brake wear on front brakes with vibration.
Good luck, I don't think you can beat the Mazda 5 for a small family car.
Hi Everyone,
I'm on the hunt for a MZ5. We have two small children and this kind of car seems perfect for us. But i have a few questions.
Prices seem to vary wildly on these cars. Here are 3 that I'm looking at right now. I'm leaning towards the cheaper 2012.
For the wife!
2013 GT 50k miles. 1 owner. $14000
2012 GT 85k miles. 1 owner. $10000
2014 GT 14k miles. 1 owner. $18500
ANNND
for me?
2007 Sport 5psd! 101K miles. 2 owner. 4.5k
Do these prices seem "fair" market value? What sort of major maintenance items should I be worried about? What common problems occur? I know what to look for in a used car in general, but what sort of specific items should i look for in a used MZ5?
That's not the OE gearshift. Looks like its from the Miata maybe? Perhaps it was an enthusiast's car and perhaps was cared for. 07s aren't as bad as 06s but they do have some 1st year/production hiccups. Mostly it will probably be plastics and electrics. Be more afraid of age than mileage on these cars. And get them up in the air. My plastic undersides and heat shields all began falling apart, and I only have 84K on an 06. Its more of a bother than anything else, except that the heat shield does finally rest right on the downpipe and resonator, and mine smoked a little bit.
But otherwise, good cars, and the MT is a great reliable powertrain.
Oh, almost forgot, all the motor mounts are DIY jobs, and you WILL end up doing all 3 while you own a used one.
Lastly, if you don't drive a lot of freeway, or at least high speeds in inclement weather or twitchy congestion, zero out the toe on the rears, it takes care of the inside tire wear, as long as rotations are done religiously.
I'm wondering if its worth looking around longer for a 2008up.
What sort of major engine maintanance should i be asking sellers?
Thanks
