Looking for advise on buying 2022-2023 CX-5 Turbo
I am looking to buy a 22-23 CX-5 Turbo, I have looked at dang near everything out there. I’m coming from a 2006 4Runner 4wd, and although I like the 4R, I’d like a little more luxury, speed and tech. The Turbo checks almost all boxes - affordable, quick, comfy, good tech, great design. What other pleasant surprises should I expect in the change from the 20 year old Toyota? Any advise, when I’m ready to pull the trigger, on what I should pay attention to in a lightly used model?
turbos should be using 5W30....so really if they have been using 0W20 you going to trust anything they say? I had 3 free oil changes when I bought mine new and used two and twice they over filled it....said right on the invoice 6 qts....was way high on the dip stick...I do it myself and 100% know it is done right.
I have a 2019 and 2025 2.5L Mazda turbo, and they both have 5W-30 on the oil cap. It seems like many shops overfill the engine oil these days… I tend to think it’s just laziness cause they don’t wanna get the oil level correct. According to the manual, the dipstick's top mark indicates maximum. Last time the dealership overfilled mine by a significant amount, I brought it back for them to correct. The service manager told me they overfill on purpose because customers don’t check their oil. I can believe that about the customers… but still.
And I haven’t found the turbo to use oil, so I don’t know why they would intentionally overfill.
Upvote 0
Somebody should explain to this auto repair supervisor why this is such a bad idea. Just sounds like a stupid excuse.
Upvote 0
Yea, probably just covering for the shop guys. It will cost me more money (probably), but I may just start telling them to use 5 quart bottles (from parts dept.) so I know it will be right… instead of filling it from their bulk supply.
Upvote 0
Well, regardless of what Mazda uses, I will use the best oil, which is synthetic meeting or exceeding the API SP standard.
You are misremembering—it is 5W30 :)
I am doing my annual change with Pennzoil Ultra Platinum in the next couple of weeks. That reminds me, I need to order a sample collection kit.
It's possible and won't be the first time. I'll check and report back once the misses arrives.
Upvote 0
I'm confused??? Are you saying not to use synthetic oil? I've been using 0w-20 synthetic for my'17 & '25 2.5 engines.
If your question is directed at me - I'm not saying not to use, I was saying that two Mazda service depts. told me that Mazda did not recommend synthetic for the turbos when I asked for syn for an oil change in my Reserve. I at the time thought it was strange since they've been using syn in my 16 Touring with the N/A engine.
0w-20 syn is correct for the 2.5 NA's.
Upvote 0
Do you really think that the service departments have anything but their own best interests/bottom lines as their primary motivators?
Mazda includes an owner's manual with every model, it's such a shame that many refuse to read it.
Upvote 0
I read the manual. Does not say anything about synthetic, only says use 5w30.
So when I tell the service dept I would like 5w30 syn and they say Mazda does not recommend syn what's a person to do.
Upvote 0
I think it's important to clarify what "does not recommend" means, because in the English language, it is used in two different and contradictory ways.
It means they "do not use" and "do not require" synthetic 0W-30. Why, I have no idea.
It does not mean "you should not use synthetic". That's because the best oil is full synthetic. It will meet and exceed all requirements of the engine.
It's fine if the service department wants to strictly go by the book to appease Mazda and meet any and all liability requirements set by their legal team. And, let's be real, any cost savings they are after. But they should be clear as to why.
Upvote 0
tell them to read the manual.......or do what I do and change my own oil.....
Upvote 0
I don't know about the Mazda's turbo, but I have read a turbo's bearings can reach 1500+ degrees Fahrenheit. I remember a test where they compared conventional motor oil to synthetic by overheating them on a metal plate. The conventional failed, having to be scraped up with a putty knife.
If I were buying a used turbo automobile, I would look for full synthetic oil changes every 5000 miles... or not much farther than that.
Upvote 0
Hmm, I would refer you to your own post (on a different thread) from a couple of years ago:
It bugged me that the Mazda branded 5W30 oil is conventional oil (in USA market) so yesterday I emailed Mazda USA thinking I would probably not get a response back, but to my surprise the next day (today) I received a reply. The reply was "Mazda recommends conventional SAE 5W-30 engine oil be used for your vehicle engine type to ensure that your vehicle operates as intended and to ensure maximum engine performance. If you would rather use synthetic engine oil for your vehicle please consult with the service department of your nearest Mazda to confirm this will not harm your vehicle." how friggin bogus is that?....Has any other car maker recommended a conventional oil in a turbo engine ever?
Upvote 0
yup thought it was bogus back then and still do today...the Mazda branded oil in Canada is synthetic and the mazda oil in the US conventional...makes zero sense. hence I change my own oil using PUP 5W30 again the manual does not mention that you can not use synthetic..just recommends using Mazda oil so if you are in Canada you would get synthetic and here conventional.
Upvote 0
When I have had my wife’s 2019 Mazda6 turbo oil changed at the Mazda dealership, they used their own Mazda branded 5W-30 synthetic oil. They said they only use synthetic in the turbo engines. For all I know, they could be putting conventional oil in there… but it says 5W-30 synthetic oil on the receipt.
I am in southern U.S.A.
Upvote 0
I understand the concern. If possible (and if it's worth it to you), you could bring it up with the service manager to see what they say, and then escalate further to Mazda Corporate to confirm that as long as the oil being used meets the certifications outlined in the manual, both conventional and synthetic are acceptable to use.
Upvote 0
