Looking for a monster engine
HKPRO5
Supercharged Protege5
My friend told me that theres a company that makes an engine for proteges 00-03 for track racing. He also said that this engine revs up to 11,000 rpm
Im really intrested in this engine. But so far my seach is in a slump. Ive tried google, yahoo. but if there was anyone that might know of such an engine..
or even if there is an engine like this please let me know.
Thanks
Thanks
Never Heard of such thing !!!!
Not sure about tindol, but Tri-Point's engines were bulit by Sunbelt Performance engines...
i've seen one of these engines here in person. they're good for about three races then require rebuilds. not what i'd recommend for a daily driver.
Thanks! i figured that the engine would be a race only....are there any interesting motor swaps for the p5?
Very, the wiring harness needs to be completely reworked. Its been done a couple times but it aint easy or all that cheep.
And this will fit in a 00-03 P5?? What else would i need? is there a kit for it
or is it a drop in?
Thanks!
I know this question has been asked a ton, but how hard would it be to do the FS swap for a KL.
There is a How to floating around on the subject.
Here is what is needed, in a nutshell:
A curve neck KL motor
MX-6 5 speed transmission, axles, starter, fly-wheel and clutch + pressure plate
Radiator from a 96 MX-6 which is OBD-2 ( BTW you can use this wiring harness, ecu and VAF if you want OBD-2, but the KL has no EGR )
Air intake oem from a MX-3 v6
Distributor and complete wiring harness from a MX-3 gs or MX-6 V6 93-95 OBD-1
Ecu KL-31 or KL-36 JDM and VAf JE-50 OBD-1
People who don't believe in the forums are nutty. The info you find is very valuable, ie: the last thread
Thanks
What Exactly you wanna build, a Track Racing Car, or a Fast Daily Dirven ? I mean by what you are looking for have to be something not street legal or much less daily driven. am I right or wrong ?
