Location of the transmission on a '08 CX-9 GT
Keoni50
2008 CX-9, GT
I just had the transmission fluid changed as a result of my problem shifting from 6 to 5 (posted in another thread.)
The dealer suggested this change because the fluid was 'dark'. I changed the oil yesterday and noticed a drain plug to the left (facing the front) of the oil pan. The plug does not look like it was opened in some time and now I'm wondering if the dealer ever changed the transmission fluid. My question is "Is the transmission directly to the left (facing the front) of the engine? And where is the transmission drain plug located?
Based on the answers here I may be paying a very stern visit to the dealer!
Thanks
Keoni50
You have a '08 right?
The transmission fluid has a dig stick under the hood.
It is easy to see if they changed the fluid.
Yes I do have an '08 but I thought the transmission was a closed system. My concern is it appears the drain plug has not been touched and or removed. No listing of a P/N for the crush washer was noted on the W/O.
I'll check under the hood for a dip stick.
Visited the dealer today and asked them how they drained the transmission fluid. They said through the service port. Apparently they have access that I can't see. Anyone hear of this 'port'?
