Location of 2012 Mazda 2 ABS relay
jayrulez
2012 Mazda 2
Hello,
Does any one here know the location of the ABS relay on this car?
My ABS pump keeps running running even when the car is switched off. For the moment, I had to pull a fuse from the fuse box for ABS. However, this also kills my speedometer and gives me a power steering and check engine warning. I've seen suggestions that the ABS relay could be stuck on on and may be need to be replaced. So far I've been unable to locate it.
I would really appreciate if someone could point me in the right direction.
Regards.
