you guys are not understanding me
1 Removed muffler. It's two bolts, but when you remove it you need to hold the exhaust up somehow so I used a exhaust manifold gasket I had laying around and supported the hanging exhaust. thats the mysterious rumble.
cost 0$
2 Intake, not just a cone filter clamped to the air flow meter. that's probably 75% problem with the stalling problem, because
1 not consistant flow through meter, due to the turbo's way of changing air flow quickly vac/boost
2 the intake air temp sensor is left outside of filter. just not where it's suppose to be
I have a 90 degree bend of intake tubing and filter from my friends prelude. Blue silicone tubing between it and the air flow meter including the air temp sensor which is mounted in the center of the AFM
cost 0$
3 BOV, you can not open vent the factory BOV. The reason you can open vent the SSQ is cause it doesn't suck. You get what you pay for.
cost doesn't matter
4 Gauge, nothing but a tuning tool........ Custom install, backing is a piece of a plastic Craftsman tool set carying case, cut with a rotozip.
gauge cost 0$ (factory VDO black face gauge from old turbo porsche in a junk yard)
gauge 0$
gauge install time 1:30 (my garage)
gauge install installation cost 0$
HAVING A MAZDASPEED PROTEGE PRICELESS
