M mazda2002 Member : mazda,protege,lx2002 Jan 21, 2004 #1 have any ove you opted for a lighter flywheel? If so did you see a difference: -in response time -in max hp -any loses in tork or displacement of torque curb -in timing (to be done or otherwise)?
M melicha8 Member Jan 21, 2004 #2 Accelleration in the lower gear increased a bit from what I've found
Z zmepro Member : Protege5 Jan 21, 2004 #3 mazda2002 said: -any loses in tork or displacement of torque curb Click to expand... it will make your car a little rougher to start from a complete standstill depending on how light you make the flywheel and your car will rev faster (good or bad you decide)
G Garrett Member : 93' RX-7 Jan 21, 2004 #4 A very good modification, can't say enough about it. I have a 9.5 pound flywheel so I'm not sure how light you are talking about. Garrett
M mp5jeff Member Jan 21, 2004 #5 if you are getting bad wheelspin with street tires, keep the stock flywheel, if you plan on running slicks then get a lighter one(just my opinion)
M mazda2002 Member : mazda,protege,lx2002 Jan 22, 2004 #6 What is the limit to where the engine starts lacking of momentum.(In weight of the flywheel) Are there good web pages that sell flywheels and give an acurate weight and description? Has anyone with a alluminium flywheel had any problems with premature use of the flywheel due to starter or other thins toching it? Where could I get more info?(web pages or books) Thanks for the replys.
M mazdaspeedpower Member Contributor : 2003.5 Titanium MSP Jan 22, 2004 #7 www.protege5online.com sells lighter ones, that's the only site I can think of off hand, other than that, just check around.
F FC3s Boy Member : 2006 forester XT, 95 eclipse 03 protege5 Jan 22, 2004 #8 i sell a 15lb on off the jdm protege if you need one $220.00
