Light Rims
What is considered a light rim in terms of pounds? I have the opportunity to buy a set of rims that weight 24.5 lbs each. Is this average, light, heavy? Looking for some knowledge on this. Thank in advance.
if u want some light rims (17lbs per rim) then look up falken, or konig, or enkei
mostly enkei and konig, falken only has one rim thats pretty light
Look up Rota Wheels, good quality and el cheepo.
MY rule of thumb is a pound per inch is a light wheel. 18" should be around 17-20 at most. 24.5 is extremely heavy.
Hey thanks for the replies guys. I will now know what to look for when buying a set of rims. I want to go 18 inch and will see if I can get anything 20lbs or less. Thanks again.
i know the stock evo 8 bbs twin 5 spoke design rims only weigh 16.5lbs each. but they are prolly pricey$$$
I'm pretty sure that the RX8 rims are lighter than ours and fit nicely as well as look good on our cars. I bet you can get a set from somebody who swapped theirs out for a good price.
explain please.
check tire weights.... its pointless to go with a lightweight rim then add a heavy tire on top of it. For the sake of simplicity:
rim=20 lbs, tire=20 =40 overall
new rim= 17 lbs, new tire=25 lbs =42 overall
ya, it's a delicate balance...you need to make sure you get high quality tires, but if it comes down to a comparison between similar tires, take the one that weighs less...:D
our OEM weights are: 24lb rims + 24lb tires.
freakin lead wheels...(yupnope)
