the rears left tire rubs when making turns only uphill right turn's going left no rub no matter what level. Now it is lowered 1/2 inch im almost sure not to much sits perfectly slighty more then an inch above tires. front suspension are some limted special edtion mazdaspeed struts previous owner told me only 4 made in this country made or something. anyways fronts levels are fine right rear sometimes can be slightly off. left rear 60% of the time i cant even fit my finger in between the tires then sometimes when i get out of the car it levels equally im only 5'11 185 pounds lol wtf. there is a single 10inch ported sub that also sits left side trunk i moved it to the right side 1 week and get a lil better level it's about 20 pounds maybe less. end link and racingbeat sway bar are off at the moment b/c bracket snaped somehow even when link and bar were on before had the same issue. torso bar i think its called (thick bar that is diagonal next to sway bar) are tight. i dont understand BTW my name mazda pro was meant for mazda protege not pro as in know it all.
Tire Size - 215/45ZR17
Rim size - 17x7.0
Bolt pattern 5-100/114.3 no stagger and wheel offset 42 rear strut is the stock tokico
Rim size - 17x7.0
